Data Retention
Once data is older than the data retention limit, it is deleted. The data retention limit (or data TTL) for an application varies depending on your platform license (or if the application is within a user’s Sandbox). If you need longer term data retention, contact us for an enterprise plan with customized data retention limits.
The default sandbox data retention limit is 30 days. Your organization’s TTL can be found on the Organization Info screen. Each application’s TTL (as inherited from the application’s owner org / sandbox) is available on the Application Info screen.
Data Subject to Retention Limits
The following resources are subject to data retention limits**:
Data Not Subject to Retention Limits
The following resources are not subject to data retention limits:
Special Retention Limits
In addition, the following data is subject to custom limits, regardless of your organization or sandbox’s data retention limit:
