Application Certificate Actions
https://api.losant.com/applications/APPLICATION_ID/certificates/APPLICATION_CERTIFICATE_ID
Below are the various requests that can be performed against the Application Certificate resource, as well as the expected parameters and the potential responses.
Delete
Deletes an application certificate
DELETE https://api.losant.com/applications/APPLICATION_ID/certificates/APPLICATION_CERTIFICATE_ID
all.Application, all.Organization, all.User, applicationCertificate.*, or applicationCertificate.delete.
| APPLICATION_CERTIFICATE_ID | ID associated with the application certificate | 575ec76c7ae143cd83dc4a96 |
| 200 | Success | If application certificate was successfully deleted |
| 404 | Error | Error if application certificate was not found |
Retrieves information on an application certificate
GET https://api.losant.com/applications/APPLICATION_ID/certificates/APPLICATION_CERTIFICATE_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationCertificate.*, or applicationCertificate.get.
| 200 | Application Certificate | Application certificate information |
Patch
Updates information about an application certificate
PATCH https://api.losant.com/applications/APPLICATION_ID/certificates/APPLICATION_CERTIFICATE_ID
all.Application, all.Organization, all.User, applicationCertificate.*, or applicationCertificate.patch.
The body of the request should be serialized JSON that validates against the Application Certificate Patch schema. For example, the following would be a valid body for this request:
"status": "active",
"description": "An example updated certificate description"
-d '{"status":"active","description":"An example updated certificate description"}' \
| 200 | Application Certificate | Updated application certificate information |
Schema for a single Application Certificate
Application Certificate Schema
- ▶{} 13 keys
Application Certificate Example
- ▶{} 11 keys
- "5cd02a50df66feb0994c7196"
- "active"
- "An example certificate description"
- ▶{} 6 keys
- "all"
- [] 0 items
- [] 0 items
Schema for the body of an Application Certificate modification request
Application Certificate Patch Schema
- ▶{} 6 keys
Application Certificate Patch Example
- "active"
- "An example updated certificate description"
Success
Success Schema
Success Example
