Application Certificate Authority Actions
https://api.losant.com/applications/APPLICATION_ID/certificate-authorities/APPLICATION_CERTIFICATE_AUTHORITY_ID
Below are the various requests that can be performed against the Application Certificate Authority resource, as well as the expected parameters and the potential responses.
Delete
Deletes an application certificate authority
DELETE https://api.losant.com/applications/APPLICATION_ID/certificate-authorities/APPLICATION_CERTIFICATE_AUTHORITY_ID
all.Application, all.Organization, all.User, applicationCertificateAuthority.*, or applicationCertificateAuthority.delete.
| APPLICATION_CERTIFICATE_AUTHORITY_ID | ID associated with the application certificate authority | 575ec76c7ae143cd83dc4a96 |
| 200 | Success | If application certificate authority was successfully deleted |
| 404 | Error | Error if application certificate authority was not found |
Retrieves information on an application certificate authority
GET https://api.losant.com/applications/APPLICATION_ID/certificate-authorities/APPLICATION_CERTIFICATE_AUTHORITY_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationCertificateAuthority.*, or applicationCertificateAuthority.get.
| 200 | Application Certificate Authority | Application certificate authority information |
Patch
Updates information about an application certificate authority
PATCH https://api.losant.com/applications/APPLICATION_ID/certificate-authorities/APPLICATION_CERTIFICATE_AUTHORITY_ID
all.Application, all.Organization, all.User, applicationCertificateAuthority.*, or applicationCertificateAuthority.patch.
The body of the request should be serialized JSON that validates against the Application Certificate Authority Patch schema. For example, the following would be a valid body for this request:
  "status": "active",
  "description": "An example updated authority description"
    -d '{"status":"active","description":"An example updated authority description"}' \
| 200 | Application Certificate Authority | Updated application certificate authority information |
Schema for a single Application Certificate Authority
Application Certificate Authority Schema
- ▶{} 3 keys- "http://json-schema.org/draft-07/schema#"
- ▶{} 10 keys- ▶{} 2 keys
Application Certificate Authority Example
- ▶{} 10 keys- "5cd02a7bdf66feb0994c7197"
- "active"
- "my certificate authority"
- "An example certificate authority description"
- "-----BEGIN CERTIFICATE-----
MY_SSL_CERTIFICATE
-----END CERTIFICATE-----"
Schema for the body of an Application Certificate Authority modification request
Application Certificate Authority Patch Schema
- ▶{} 4 keys- "http://json-schema.org/draft-07/schema#"
- ▶{} 4 keys- ▶{} 3 keys
Application Certificate Authority Patch Example
- ▶{} 2 keys- "active"
- "An example updated authority description"
- ▶{} 2 keys- ▶{} 1 key
- ▶{} 2 keys- "NotFound"
Success
Success Schema
- ▶{} 1 key- ▶{} 2 keys
Success Example
- ▶{} 1 key- true
