Application Certificates Actions
/certificates
Below are the various requests that can be performed against the Application Certificates resource, as well as the expected parameters and the potential responses.
Returns the application certificates for an application
/certificates
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationCertificates.*, or applicationCertificates.get.
sortField | N | Field to sort the results by. Accepted values are: certificateInfo.commonName, status, id, creationDate, lastUpdated | certificateInfo.commonName | sortField=status |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: certificateInfo.commonName, status | filterField=status | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=the*status |
https://api.losant.com/applications/APPLICATION_ID/certificates
Code | Type | Description |
200 | Application Certificates | Collection of application certificates |
Create a new application certificate for an application
/certificates
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, applicationCertificates.*, or applicationCertificates.post.
The body of the request should be serialized JSON that validates against the Application Certificate Post schema. For example, the following would be a valid body for this request:
"description": "An example new certificate description",
"certificate": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----",
"filterType": "all",
"pubTopics": [],
"subTopics": []
-d '{"description":"An example new certificate description","certificate":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----","filterType":"all","pubTopics":[],"subTopics":[]}' \
201 | Application Certificate | Successfully created application certificate |
