Application Dashboard Actions
https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
Below are the various requests that can be performed against the Application Dashboard resource, as well as the expected parameters and the potential responses.
Delete
Deletes a dashboard
DELETE https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, applicationDashboard.*, or applicationDashboard.delete.
DASHBOARD_ID ID of the associated dashboard 575ece2b7ae143cd83dc4a9b
APPLICATION_ID ID of the associated application 575ec8687ae143cd83dc4a97
Name Required Description Default
Code Type Description
200 Success If dashboard was successfully deleted
404 Error Error if dashboard was not found
Retrieves information on a dashboard
GET https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationDashboard.*, or applicationDashboard.get.
200 Dashboard Dashboard information
Patch
Updates information about a dashboard
PATCH https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, applicationDashboard.*, or applicationDashboard.patch.
The body of the request should be serialized JSON that validates against the Dashboard Patch schema. For example, the following would be a valid body for this request:
  "name": "My Updated Dashboard",
  "description": "Description of my updated dashboard",
  "refreshRate": 300,
  "public": true
    -d '{"name":"My Updated Dashboard","description":"Description of my updated dashboard","refreshRate":300,"public":true}' \
200 Dashboard Update dashboard information
Send Report
Sends a snapshot of a dashboard
POST https://api.losant.com/applications/APPLICATION_ID/dashboards/DASHBOARD_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationDashboard.*, or applicationDashboard.sendReport.
The body of the request should be serialized JSON that validates against the Dashboard Send Report schema. For example, the following would be a valid body for this request:
  "toEmail": [
    "email@example.com"
  "subject": "Dashboard Report",
  "message": "Lookit",
  "time": 1551887386704,
  "theme": "dark",
  "timezone": "America/New_York",
  "locale": "en-us"
    -d '{"toEmail":["email@example.com"],"subject":"Dashboard Report","message":"Lookit","time":1551887386704,"theme":"dark","timezone":"America/New_York","locale":"en-us"}' \
202 Job Enqueued API Result If dashboard report was enqueued to be sent
