Application Template Actions
https://api.losant.com/applicationTemplates/TEMPLATE_ID
Below are the various requests that can be performed against the Application Template resource, as well as the expected parameters and the potential responses.
Retrieves information on an application template
GET https://api.losant.com/applicationTemplates/TEMPLATE_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.read, applicationTemplate.*, or applicationTemplate.get.
TEMPLATE_ID | ID associated with the template | 575ed0de7ae143cd83dc4aa5 |
Code | Type | Description |
200 | Application Template | Application template information |
404 | Error | Error if template was not found |
