Audit Log Actions
https://api.losant.com/orgs/ORG_ID/audit-logs/AUDIT_LOG_ID
Below are the various requests that can be performed against the Audit Log resource, as well as the expected parameters and the potential responses.
Retrieves information on an audit log
GET https://api.losant.com/orgs/ORG_ID/audit-logs/AUDIT_LOG_ID
all.Organization, all.Organization.read, all.User, all.User.read, auditLog.*, or auditLog.get.
| ORG_ID | ID associated with the organization | 575ed6e87ae143cd83dc4aa8 |
| AUDIT_LOG_ID | ID associated with the audit log | 57955788124b37010084c053 |
| 200 | Audit Log | Audit log information |
| 404 | Error | Error if audit log was not found |
Audit Log
Schema for a single Audit Log entry
Audit Log Schema
- ▶{} 20 keys
Audit Log Example
- ▶{} 17 keys
- "586e9d5151265cb9d72f6ec6"
- "575ed6e87ae143cd83dc4aa8"
- "Application"
- "My Application"
- "575ed70c7ae143cd83dc4aa9"
- "User"
- "actor@example.com"
- "application"
- "delete"
- {} 0 keys
- {} 0 keys
- 200
