Data Table Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
Below are the various requests that can be performed against the Data Table resource, as well as the expected parameters and the potential responses.
Add Column
Adds a new column to this data table
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column
all.Application, all.Organization, all.User, dataTable.*, or dataTable.addColumn.
| DATA_TABLE_ID | ID associated with the data table | 575ed78e7ae143cd83dc4aab |
The body of the request should be serialized JSON that validates against the Data Table Column schema. For example, the following would be a valid body for this request:
"name": "myColumn3",
"dataType": "string",
"constraint": "optional",
"defaultValue": "aDefault"
-d '{"name":"myColumn3","dataType":"string","constraint":"optional","defaultValue":"aDefault"}' \
| 200 | Data Table | Updated data table information |
| 404 | Error | Error if data table was not found |
Delete
Deletes a data table
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
all.Application, all.Organization, all.User, dataTable.*, or dataTable.delete.
| 200 | Success | If data table was successfully deleted |
Retrieves information on a data table
GET https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, dataTable.*, or dataTable.get.
| 200 | Data Table | Data table information |
Patch
Updates information about a data table
PATCH https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID
all.Application, all.Organization, all.User, dataTable.*, or dataTable.patch.
The body of the request should be serialized JSON that validates against the Data Table Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Data Table"
-d '{"name":"My Updated Data Table"}' \
Remove Column
Removes a column from this data table
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column
all.Application, all.Organization, all.User, dataTable.*, or dataTable.removeColumn.
| columnName | Y | Name of the column to remove | columnName=myColumnName |
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/column?columnName=myColumnName
Data Table
Schema for a single Data Table
Data Table Schema
- ▶{} 8 keys
Data Table Example
- ▶{} 7 keys
- "596e6ce831761df4231708f1"
- "My Data Table"
- ▶[] 2 items
Data Table Column
Schema for a single Data Table Column
Data Table Column Schema
- ▶[] 3 items
Data Table Column Example
- "myColumn3"
- "string"
- "optional"
- "aDefault"
Data Table Patch
Schema for the body of a Data Table modification request
Data Table Patch Schema
Data Table Patch Example
- "My Updated Data Table"
Success
Success Schema
Success Example
