Data Table Row Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
Below are the various requests that can be performed against the Data Table Row resource, as well as the expected parameters and the potential responses.
Delete
Deletes a data table row
DELETE https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTableRow.*, or dataTableRow.delete.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
DATATABLEID ID associated with the data table 575ed78e7ae143cd83dc4aab
ROW_ID ID associated with the data table row 596f832b128eda5cfe765443
Name Required Description Default
Code Type Description
200 Success If data table row was successfully deleted
404 Error Error if data table row was not found
Retrieves the data table row
GET https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, dataTableRow.*, or dataTableRow.get.
200 Data Table Row Data table row information
Patch
Updates the data table row
PATCH https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/ROW_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTableRow.*, or dataTableRow.patch.
The body of the request should be serialized JSON that validates against the Data Table Row Insert Update schema. For example, the following would be a valid body for this request:
  "myColumn1": "myValue"
    -d '{"myColumn1":"myValue"}' \
200 Data Table Row Updated data table row information
