Data Table Rows Actions
https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows
Below are the various requests that can be performed against the Data Table Rows resource, as well as the expected parameters and the potential responses.
Delete
Delete rows from a data table
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/delete
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTableRows.*, or dataTableRows.delete.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
DATATABLEID ID associated with the data table 575ed78e7ae143cd83dc4aab
Name Required Description Default Example
limit N Limit number of rows to delete from data table 1000 limit=10
The body of the request should be serialized JSON that validates against the Advanced Query schema. For example, the following would be a valid body for this request:
  "$or": [
      "level": {
        "$ne": "myValue"
      "level": 5
Code Type Description
200 Data Table Rows Delete If request successfully deletes a set of Data Table rows
404 Error Error if data table was not found
Export
Request an export of the data table’s data
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/export
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, dataTableRows.*, or dataTableRows.export.
The body of the request should be serialized JSON that validates against the Data Table Rows Export schema. For example, the following would be a valid body for this request:
  "email": "email@example.com",
  "query": {
    "$or": [
        "myColumn1": {
          "$ne": "myValue"
        "myColumn2": 5
  "queryOptions": {
    "limit": 10000
    -d '{"email":"email@example.com","query":{"$or":[{"myColumn1":{"$ne":"myValue"}},{"myColumn2":5}]},"queryOptions":{"limit":10000}}' \
202 Job Enqueued API Result If request was successfully queued
Returns the rows for a data table
GET https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, dataTableRows.*, or dataTableRows.get.
sortColumn N Column to sort the rows by sortColumn=myColumnName
sortDirection N Direction to sort the rows by. Accepted values are: asc, desc asc sortDirection=asc
limit N How many rows to return 1000 limit=0
offset N How many rows to skip 0 offset=0
includeFields N Comma-separated list of fields to include in resulting rows. When not provided, returns all fields. includeFields=id,createdAt
200 Data Table Rows Collection of data table rows
Inserts a new row(s) into a data table
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTableRows.*, or dataTableRows.post.
The body of the request should be serialized JSON that validates against the Data Table Row Insert schema. For example, the following would be a valid body for this request:
  "myColumn1": "myValue"
    -d '{"myColumn1":"myValue"}' \
201 Data Table Row Insert Result Successfully created data table row, or bulk insert count
Query
Queries for rows from a data table
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/query
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, dataTableRows.*, or dataTableRows.query.
  "$or": [
      "level": {
        "$ne": "myValue"
      "level": 5
Truncate
Delete all data in the data table
POST https://api.losant.com/applications/APPLICATION_ID/data-tables/DATA_TABLE_ID/rows/truncate
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTableRows.*, or dataTableRows.truncate.
200 Success If request successfully deleted all rows in the data table, this will not send workflow data table deletion triggers
