Data Tables Actions
/data-tables
Below are the various requests that can be performed against the Data Tables resource, as well as the expected parameters and the potential responses.
Returns the data tables for an application
/data-tables
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, dataTables.*, or dataTables.get.
sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*table |
https://api.losant.com/applications/APPLICATION_ID/data-tables
Code | Type | Description |
200 | Data Tables | Collection of data tables |
Create a new data table for an application
/data-tables
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, dataTables.*, or dataTables.post.
The body of the request should be serialized JSON that validates against the Data Table Post schema. For example, the following would be a valid body for this request:
"name": "My Data Table",
"columns": [
"name": "myColumn1",
"dataType": "string",
"constraint": "unique"
"name": "myColumn2",
"dataType": "number",
"constraint": "optional"
-d '{"name":"My Data Table","columns":[{"name":"myColumn1","dataType":"string","constraint":"unique"},{"name":"myColumn2","dataType":"number","constraint":"optional"}]}' \
201 | Data Table | Successfully created data table |
