Embedded Deployments Actions
https://api.losant.com/applications/APPLICATION_ID/embedded/deployments
Below are the various requests that can be performed against the Embedded Deployments resource, as well as the expected parameters and the potential responses.
Export
Request an export of the compiled WASM files for a current deployment
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/export
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, embeddedDeployments.*, or embeddedDeployments.export.
The body of the request should be serialized JSON that validates against the Embedded Deployment Export schema. For example, the following would be a valid body for this request:
"email": "email@example.com",
"deviceId": "575ecf887ae143cd83dc4aa2"
| 202 | Job Enqueued API Result | If generation of export was successfully started |
| 404 | Error | Error if deployment was not found |
Returns the embedded deployments for an application
GET https://api.losant.com/applications/APPLICATION_ID/embedded/deployments
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, embeddedDeployments.*, or embeddedDeployments.get.
| sortField | N | Field to sort the results by. Accepted values are: id, creationDate, lastUpdated | lastUpdated | sortField=creationDate |
| sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=asc |
| perPage | N | How many items to return per page | 1000 | perPage=10 |
| deviceId | N | Filter deployments to the given Device ID | deviceId=575ecf887ae143cd83dc4aa2 | |
| version | N | Filter deployments to the given Workflow Version (matches against both current and desired) | version=myFlowVersion | |
| flowId | N | Filter deployments to the given Workflow ID | flowId=575ed18f7ae143cd83dc4aa6 |
| 200 | Embedded Deployments | Collection of embedded deployments |
| 404 | Error | Error if application or device was not found |
Release
Deploy an embedded workflow version to one or more embedded devices. Version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/release
all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.release.
The body of the request should be serialized JSON that validates against the Embedded Deployment Release schema. For example, the following would be a valid body for this request:
"flowId": "575ed18f7ae143cd83dc4aa6",
"version": "v1.2.3",
"deviceIds": [
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","version":"v1.2.3","deviceIds":["575ecf887ae143cd83dc4aa2"]}' \
| 201 | Success | If deployment release has been initiated successfully |
Remove
Remove all embedded deployments from a device, remove all embedded deployments of a workflow, or remove a specific workflow from a specific device
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/remove
all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.remove.
The body of the request should be serialized JSON that validates against the Embedded Deployment Remove schema. For example, the following would be a valid body for this request:
"deviceId": null
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","deviceId":null}' \
| 201 | Success | If deployment removal has been initiated successfully |
Replace
Replace deployments of an embedded workflow version with a new version. New version can be blank, if removal is desired.
POST https://api.losant.com/applications/APPLICATION_ID/embedded/deployments/replace
all.Application, all.Organization, all.User, embeddedDeployments.*, or embeddedDeployments.replace.
The body of the request should be serialized JSON that validates against the Embedded Deployment Replace schema. For example, the following would be a valid body for this request:
"oldVersion": "v1.2.3",
"newVersion": "v1.2.4"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","oldVersion":"v1.2.3","newVersion":"v1.2.4"}' \
| 201 | Success | If deployment replacement has been initiated successfully |
Schema for the body of a compiled embedded deployment files request
Embedded Deployment Export Schema
- ▶{} 10 keys
Embedded Deployment Export Example
- "email@example.com"
- "575ecf887ae143cd83dc4aa2"
Schema for deploying an embedded workflow to one or more edge devices
Embedded Deployment Release Schema
- ▶[] 2 items
Embedded Deployment Release Example
- "575ed18f7ae143cd83dc4aa6"
- "v1.2.3"
Schema for removing embedded deployments. Can remove a specific workflow from a specific device, can remove all workflows from a specific device, or can remove a specific workflow from all devices.
Embedded Deployment Remove Schema
- ▶[] 2 items
Embedded Deployment Remove Example
- null
Schema for replacing a deployment of a workflow version with a different workflow version
Embedded Deployment Replace Schema
- ▶[] 3 items
Embedded Deployment Replace Example
- "v1.2.3"
- "v1.2.4"
Schema for a collection of Embedded Deployments
Embedded Deployments Schema
- ▶{} 7 keys
Embedded Deployments Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "id"
- "asc"
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
Success
Success Schema
Success Example
