Experience Domain Actions
https://api.losant.com/applications/APPLICATION_ID/experience/domains/EXPERIENCE_DOMAIN_ID
Below are the various requests that can be performed against the Experience Domain resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience domain
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/domains/EXPERIENCE_DOMAIN_ID
all.Application, all.Organization, all.User, experienceDomain.*, or experienceDomain.delete.
| EXPERIENCE_DOMAIN_ID | ID associated with the experience domain | 575ed78e7ae143cd83dc4aab |
| 200 | Success | If experience domain was successfully deleted |
| 404 | Error | Error if experience domain was not found |
Retrieves information on an experience domain
GET https://api.losant.com/applications/APPLICATION_ID/experience/domains/EXPERIENCE_DOMAIN_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceDomain.*, or experienceDomain.get.
| 200 | Experience Domain | Experience domain information |
Patch
Updates information about an experience domain
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/domains/EXPERIENCE_DOMAIN_ID
all.Application, all.Organization, all.User, experienceDomain.*, or experienceDomain.patch.
The body of the request should be serialized JSON that validates against the Experience Domain Patch schema. For example, the following would be a valid body for this request:
"domainName": "my.domain.example.com",
"sslCert": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----",
"sslKey": "-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----",
"version": "develop"
-d '{"domainName":"my.domain.example.com","sslCert":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----","sslKey":"-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----","version":"develop"}' \
| 200 | Experience Domain | Updated experience domain information |
Experience Domain
Schema for a single Experience Domain
Experience Domain Schema
- ▶{} 9 keys
Experience Domain Example
- ▶{} 7 keys
- "58c1de6c8f812590d8e82980"
- "my.domain.example.com"
- "develop"
Schema for the body of an Experience Domain modification request
Experience Domain Patch Schema
Experience Domain Patch Example
- "-----BEGIN CERTIFICATE-----
MY_SSL_CERTIFICATE
- "-----BEGIN PRIVATE KEY-----
MY_SSL_KEY
- "develop"
Success
Success Schema
Success Example
