Experience Endpoints Actions
https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
Below are the various requests that can be performed against the Experience Endpoints resource, as well as the expected parameters and the potential responses.
Returns the experience endpoints for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoints.*, or experienceEndpoints.get.
| sortField | N | Field to sort the results by. Accepted values are: order, method, route, id, creationDate, requestCount, lastUpdated | order | sortField=order |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: method, route | filterField=method | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*route | |
| experienceGroupId | N | Filter endpoints to those only in the specified group | experienceGroupId=575ec8687ae143cd83dc4a97 | |
| requestCountDuration | N | If set, a count of recent requests is included on each endpoint for the duration requested (milliseconds) | requestCountDuration=86400000 | |
| version | N | Return the experience endpoints belonging to this version | develop | version=develop |
| 200 | Experience Endpoints | Collection of experience endpoints |
Create a new experience endpoint for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/endpoints
all.Application, all.Organization, all.User, experienceEndpoints.*, or experienceEndpoints.post.
The body of the request should be serialized JSON that validates against the Experience Endpoint Post schema. For example, the following would be a valid body for this request:
"route": "/my/route/{id}",
"method": "get",
"access": "public"
-d '{"route":"/my/route/{id}","method":"get","access":"public"}' \
| 201 | Experience Endpoint | Successfully created experience endpoint |
Stats
Get statistics about endpoint requests
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/stats
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceEndpoints.*, or experienceEndpoints.stats.
| statGrouping | N | Field to group the statistics by. Accepted values are: statusCode, endpointId, version, domain | statusCode | statGrouping=statusCode |
| duration | N | Duration in milliseconds | 86400000 | duration=86400000 |
| end | N | End of time range in milliseconds since epoch | 0 | end=0 |
| resolution | N | Resolution in milliseconds | 3600000 | resolution=3600000 |
| versionFilter | N | Filters the stats to a particular experience version | versionFilter=myVersion | |
| domainFilter | N | Filters the stats to a particular experience domain or slug | domainFilter=example.com | |
| statusCodeFilter | N | Filters the stats to a particular status code | statusCodeFilter=200 | |
| endpointIdFilter | N | Filters the stats to a particular endpoint | endpointIdFilter=575ec8687ae143cd83dc4a98 |
| 200 | Experience Endpoint Stats | Statistics for endpoint requests |
Experience Endpoint
Schema for a single Experience Endpoint
Experience Endpoint Schema
- ▶{} 19 keys
Experience Endpoint Example
- ▶{} 10 keys
- "58c1de6c8f812590d8e82980"
- "/my/route/{id}"
- "get"
- "group"
Schema for the body of an Experience Endpoint creation request
Experience Endpoint Post Schema
- ▶{} 10 keys
- ▶[] 2 items
Experience Endpoint Post Example
- "/my/route/{id}"
- "get"
- "public"
Schema for stats for an experience's endpoints
Experience Endpoint Stats Schema
Experience Endpoint Stats Example
- ▶[] 2 items
- ▶[] 2 items
Schema for a collection of Experience Endpoints
Experience Endpoints Schema
- ▶{} 10 keys
Experience Endpoints Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
