Experience Versions Actions
https://api.losant.com/applications/APPLICATION_ID/experience/versions
Below are the various requests that can be performed against the Experience Versions resource, as well as the expected parameters and the potential responses.
Returns the experience versions for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/versions
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceVersions.*, or experienceVersions.get.
| sortField | N | Field to sort the results by. Accepted values are: version, id, creationDate, lastUpdated | version | sortField=version |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: version | filterField=email | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*version |
| 200 | Experience Versions | Collection of experience versions |
Create a new experience version for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/versions
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, experienceVersions.*, or experienceVersions.post.
The body of the request should be serialized JSON that validates against the Experience Version Post schema. For example, the following would be a valid body for this request:
"version": "myNewVersion",
"description": "my version description",
"domainIds": [
"58c1de6c8f812590d8e82980"
"slugIds": [
"5b995e51ea9994b50d745284"
-d '{"version":"myNewVersion","description":"my version description","domainIds":["58c1de6c8f812590d8e82980"],"slugIds":["5b995e51ea9994b50d745284"]}' \
| 201 | Experience Version | Successfully created experience version |
Experience Version
Schema for a single Experience Version
Experience Version Schema
- ▶{} 19 keys
Experience Version Example
- ▶{} 9 keys
- "5b995ec6ea9994b50d745285"
- "myVersionName"
Schema for the body of an Experience Version creation request
Experience Version Post Schema
- ▶{} 10 keys
Experience Version Post Example
- "myNewVersion"
- "my version description"
Experience Versions
Schema for a collection of Experience Versions
Experience Versions Schema
Experience Versions Example
- 1
- 1
