Experience View Actions
https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID
Below are the various requests that can be performed against the Experience View resource, as well as the expected parameters and the potential responses.
Delete​
Deletes an experience view
Method And Url​
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.cli, all.Organization, all.Organization.bounded, all.User, all.User.bounded, all.User.cli, experienceView.*, or experienceView.delete.
Request Path Components​
EXPERIENCE_VIEW_IDID associated with the experience view575ed78e7ae143cd83dc4aab
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf experience view was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if experience view was not found
Get​
Retrieves information on an experience view
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.cli, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.cli, all.User.read, experienceView.*, or experienceView.get.
Request Query Parameters​
versionNVersion of this experience view to returndevelopversion=develop
Request Headers​
Curl Example​
CodeTypeDescription
200Experience ViewExperience view information
Error Responses​
CodeTypeDescription
Linked Resources​
Retrieves information on resources linked to an experience view
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID/linkedResources
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.cli, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.cli, all.User.read, experienceView.*, or experienceView.linkedResources.
versionNVersion of this experience view to querydevelopversion=develop
includeCustomNodesNIf the result of the request should also include the details of any custom nodes referenced by returned workflowsfalseincludeCustomNodes=true
Request Headers​
Curl Example​
CodeTypeDescription
200Experience Linked ResourcesLinked resource information
Error Responses​
CodeTypeDescription
Patch​
Updates information about an experience view
Method And Url​
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/views/EXPERIENCE_VIEW_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.cli, all.Organization, all.Organization.bounded, all.User, all.User.bounded, all.User.cli, experienceView.*, or experienceView.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Experience View Patch schema. For example, the following would be a valid body for this request:
"body": "New Content! <p>{{newData}}</p>",
"viewTags": {
"customKey": "newCustomValue"
Curl Example​
-d '{"body":"New Content! <p>{{newData}}</p>","viewTags":{"customKey":"newCustomValue"}}' \
CodeTypeDescription
200Experience ViewUpdated experience view information
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Experience Linked Resources​
        The body of an experience linked resources response
        Experience Linked Resources Schema​
          {} 4 keys
          • "object"
            {} 4 keys
              {} 4 keys
                {} 4 keys
                  {} 4 keys
                    {} 4 keys
                  • false
                Experience Linked Resources Example​
                  {} 4 keys
                    {} 8 keys
                      {} 8 keys
                        {} 8 keys
                          {} 9 keys
                        Experience View​
                        Schema for a single Experience View
                        Experience View Schema​
                          {} 3 keys
                          • "object"
                            {} 18 keys
                              {} 2 keys
                                {} 2 keys
                                  {} 2 keys
                                    {} 2 keys
                                      {} 2 keys
                                        {} 2 keys
                                          {} 2 keys
                                            {} 2 keys
                                              {} 2 keys
                                                {} 3 keys
                                                  {} 3 keys
                                                    {} 2 keys
                                                      {} 2 keys
                                                        {} 2 keys
                                                          {} 3 keys
                                                            {} 2 keys
                                                              {} 3 keys
        {} 3 keys
                                                            Experience View Example​
                                                              {} 10 keys
                                                              • "59cc5c628246c6caed4b16c1"
                                                              • "575ec8687ae143cd83dc4a97"
                                                              • "2016-06-13T04:00:00.000Z"
                                                              • "My Page View"
                                                              • "page"
                                                              • "<p>{{data}}</p>"
                                                              • "59cc5cad8246c6caed4b16c2"
        {} 1 key
                                                              Experience View Patch​
                                                              Schema for the body of an Experience View modification request
                                                              Experience View Patch Schema​
        {} 4 keys
        • "object"
        {} 6 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 3 keys
        • false
        Experience View Patch Example​
        {} 2 keys
        • "New Content! <p>{{newData}}</p>"
        {} 1 key
        Success​
        Success Schema​
        {} 3 keys
        • "object"
        {} 1 key
        {} 2 keys
        Success Example​
        {} 1 key
        • true
