Experience Views Actions
https://api.losant.com/applications/APPLICATION_ID/experience/views
Below are the various requests that can be performed against the Experience Views resource, as well as the expected parameters and the potential responses.
Returns the experience views for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/views
all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceViews.*, or experienceViews.get.
| sortField | N | Field to sort the results by. Accepted values are: id, creationDate, name, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*view | |
| viewType | N | Filter views to those only of the given type. Accepted values are: page, layout, component | viewType=page | |
| version | N | Return the experience views belonging to this version | develop | version=develop |
| 200 | Experience Views | Collection of experience views |
Create a new experience view for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/views
all.Application, all.Application.cli, all.Organization, all.User, all.User.cli, experienceViews.*, or experienceViews.post.
The body of the request should be serialized JSON that validates against the Experience View Post schema. For example, the following would be a valid body for this request:
"name": "My Page View",
"viewType": "page",
"body": "<p>{{data}}</p>",
"layoutId": "59cc5cad8246c6caed4b16c2",
"viewTags": {
"customKey": "customValue"
-d '{"name":"My Page View","viewType":"page","body":"<p>{{data}}</p>","layoutId":"59cc5cad8246c6caed4b16c2","viewTags":{"customKey":"customValue"}}' \
| 201 | Experience View | Successfully created experience view |
Experience View
Schema for a single Experience View
Experience View Schema
- ▶{} 17 keys
Experience View Example
- ▶{} 10 keys
- "59cc5c628246c6caed4b16c1"
- "My Page View"
- "page"
- "<p>{{data}}</p>"
- "59cc5cad8246c6caed4b16c2"
Schema for the body of an Experience View creation request
Experience View Post Schema
- ▶{} 7 keys
- ▶[] 2 items
Experience View Post Example
- "My Page View"
- "page"
- "<p>{{data}}</p>"
Experience Views
Schema for a collection of Experience Views
Experience Views Schema
- ▶{} 11 keys
Experience Views Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
