Instance Audit Logs Actions
https://api.losant.com/instance/INSTANCE_ID/audit-logs
Below are the various requests that can be performed against the Instance Audit Logs resource, as well as the expected parameters and the potential responses.
Returns the audit logs for the instance
GET https://api.losant.com/instance/INSTANCE_ID/audit-logs
all.Instance, all.Instance.read, all.User, all.User.read, instanceAuditLogs.*, or instanceAuditLogs.get.
| INSTANCE_ID | ID associated with the instance | 575ec7417ae143cd83dc4a96 |
| sortField | N | Field to sort the results by. Accepted values are: creationDate, responseStatus, actorName | creationDate | sortField=creationDate |
| sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=asc |
| start | N | Start of time range for audit log query | start=1465790400000 | |
| end | N | End of time range for audit log query | end=1465790400000 | |
| auditLogFilter | N | Filters for the audit log query. See Instance Audit Log Filter for more details. | auditLogFilter[primaryTarget][0][type]=Organization&auditLogFilter[primaryTarget][1][type]=ApiToken&auditLogFilter[primaryTarget][1][id]=575ec8687ae143cd83dc4a97&auditLogFilter[actor][0][type]=User&auditLogFilter[actor][0][id]=575ed70c7ae143cd83dc4aa9 |
| 200 | Instance Audit Logs | Collection of instance audit logs |
| 404 | Error | Error if instance was not found |
Schema for the filter of an instance audit log query
Instance Audit Log Filter Schema
Instance Audit Log Filter Example
- ▶[] 2 items
Instance Audit Logs
Schema for a collection of Instance Audit Logs
Instance Audit Logs Schema
- ▶{} 8 keys
Instance Audit Logs Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "creationDate"
- "desc"
- "575ed6e87ae143cd83dc4aa8"
