Instance Custom Node Actions
https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID
Below are the various requests that can be performed against the Instance Custom Node resource, as well as the expected parameters and the potential responses.
Delete​
Deletes a Custom Node
Method And Url​
DELETE https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceCustomNode.*, or instanceCustomNode.delete.
Request Path Components​
INSTANCE_IDID associated with the instance575ec7417ae143cd83dc4a96
INSTANCE_CUSTOM_NODE_IDID associated with the Custom Node575ec7417ae143cd83dc4a95
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf Custom Node was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if Custom Node was not found
Errors​
Get information about errors that occurred during runs of this Custom Node
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID/errors
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceCustomNode.*, or instanceCustomNode.errors.
Request Query Parameters​
durationNDuration of time range in milliseconds86400000duration=86400000
endNEnd of time range in milliseconds since epoch0end=0
limitNMaximum number of errors to return25limit=25
sortDirectionNDirection to sort the results by. Accepted values are: asc, descdescsortDirection=desc
Request Headers​
Curl Example​
CodeTypeDescription
200Workflow ErrorsCustom Node error information
Error Responses​
CodeTypeDescription
Get​
Retrieves information on a Custom Node
Method And Url​
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceCustomNode.*, or instanceCustomNode.get.
Request Headers​
Curl Example​
CodeTypeDescription
200Instance Custom NodeCustom Node information
Error Responses​
CodeTypeDescription
Patch​
Updates information about a Custom Node
Method And Url​
PATCH https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.User, all.User.bounded, instanceCustomNode.*, or instanceCustomNode.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Instance Custom Node Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated Instance Custom Node",
"category": "logic"
Curl Example​
-d '{"name":"My Updated Instance Custom Node","category":"logic"}' \
CodeTypeDescription
200Instance Custom NodeUpdated Custom Node information
Error Responses​
CodeTypeDescription
Stats​
Get statistics about runs for this Custom Node
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/nodes/INSTANCE_CUSTOM_NODE_ID/stats
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceCustomNode.*, or instanceCustomNode.stats.
resolutionNResolution in milliseconds3600000resolution=3600000
Request Headers​
Curl Example​
CodeTypeDescription
200Workflow StatisticsStatistics for Custom Node runs
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Workflow Errors​
        Workflow run error information
        Workflow Errors Schema​
          {} 3 keys
          • "object"
            {} 8 keys
              {} 3 keys
                {} 2 keys
                  {} 2 keys
                    {} 2 keys
                      {} 2 keys
                        {} 1 key
                          {} 2 keys
                            {} 2 keys
                        Workflow Errors Example​
                          {} 5 keys
                          • "2016-06-03T00:00:00.000Z"
                          • "2016-06-04T00:00:00.000Z"
                          • 25
                          • "desc"
                            [] 1 item
                          Workflow Statistics​
                          Statistics about the runs for a given workflow
                          Workflow Statistics Schema​
                            {} 3 keys
                            • "object"
                              {} 7 keys
                                {} 3 keys
                                  {} 2 keys
                                    {} 2 keys
                                      {} 2 keys
                                        {} 2 keys
                                          {} 1 key
                                            {} 2 keys
                                        Workflow Statistics Example​
                                          {} 4 keys
                                          • 86400000
                                            [] 1 item
                                          Instance Custom Node​
                                          Schema for a single Instance Custom Node
                                          Instance Custom Node Schema​
                                            {} 3 keys
                                            • "object"
                                              {} 25 keys
                                                {} 2 keys
                                                  {} 2 keys
                                                    {} 2 keys
                                                      {} 2 keys
                                                        {} 2 keys
                                                          {} 2 keys
                                                            {} 2 keys
                                                              {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 2 keys
        {} 4 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 3 keys
        {} 4 keys
        Instance Custom Node Example​
        {} 11 keys
        • "575ed18f7ae143cd83dc4aa6"
        • "575ec8687ae143cd83dc4a97"
        • "2016-06-13T04:00:00.000Z"
        • "My Instance Custom Node"
        • "Description of my instance custom node"
        [] 1 item
        [] 1 item
        {} 1 key
        {} 2 keys
        Instance Custom Node Patch​
        Schema for the body of an Instance Custom Node modification request
        Instance Custom Node Patch Schema​
        {} 5 keys
        • "object"
        {} 11 keys
        {} 3 keys
        {} 2 keys
        {} 2 keys
        {} 1 key
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 4 keys
        {} 3 keys
        {} 1 key
        • 25
        Instance Custom Node Patch Example​
        {} 2 keys
        • "My Updated Instance Custom Node"
        • "logic"
        Success​
        Success Schema​
        {} 3 keys
        • "object"
        {} 1 key
        {} 2 keys
        Success Example​
        {} 1 key
        • true
