Instance Organization Invites Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites
Below are the various requests that can be performed against the Instance Organization Invites resource, as well as the expected parameters and the potential responses.
Get​
Returns a collection of instance organization invites
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceOrgInvites.*, or instanceOrgInvites.get.
Request Path Components​
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a97
ORG_IDID associated with the organization575ec8687ae143cd83dc4a97
Request Query Parameters​
sortFieldNField to sort the results by. Accepted values are: email, role, inviteDateinviteDatesortField=role
sortDirectionNDirection to sort the results by. Accepted values are: asc, descdescsortDirection=asc
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: email, rolefilterField=email
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my * instance
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200Instance Organization InvitationsA collection of instance organization invitations
Error Responses​
CodeTypeDescription
404ErrorError if instance or organization was not found
Post​
Invites a member to an instance organization
Method And Url​
POST https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/invites
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgInvites.*, or instanceOrgInvites.post.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Organization Invitation Post schema. For example, the following would be a valid body for this request:
"email": "invitedUser@example.com",
"role": "edit"
Curl Example​
-d '{"email":"invitedUser@example.com","role":"edit"}' \
CodeTypeDescription
201Instance Organization InvitationThe new organization invite
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Instance Organization Invitation​
        Schema for a pending invitation to an Organization within an instance
        Instance Organization Invitation Schema​
          {} 3 keys
          • "object"
            {} 12 keys
              {} 2 keys
                {} 3 keys
                  {} 2 keys
                    {} 3 keys
                      {} 3 keys
                        {} 2 keys
                          {} 1 key
                            {} 1 key
                              {} 1 key
                                {} 2 keys
                                  {} 2 keys
                                    {} 2 keys
                                Instance Organization Invitation Example​
                                  {} 12 keys
                                  • "575ec8687ae143cd83dc4a97"
                                  • "test@example.com"
                                  • "admin"
                                  • [] 0 items
                                    • [] 0 items
                                      • "2016-06-13T04:00:00.000Z"
                                      • 604800000
                                      • false
                                      • false
                                      • "575ec8687ae143cd83dc4a98"
                                      • "575ec8687ae143cd83dc4a99"
                                    Instance Organization Invitations​
                                    Schema for a collection of pending invitations to an Instance Organization
                                    Instance Organization Invitations Schema​
                                      {} 3 keys
                                      • "object"
                                        {} 9 keys
                                          {} 2 keys
                                            {} 2 keys
                                              {} 2 keys
                                                {} 1 key
                                                  {} 1 key
                                                    {} 1 key
                                                      {} 1 key
                                                        {} 1 key
                                                          {} 2 keys
                                                      Instance Organization Invitations Example​
                                                        {} 4 keys
                                                          [] 1 item
                                                          • 8
                                                          • "role"
                                                          • "asc"
                                                        Organization Invitation Post​
                                                        Schema for the body of a request to send an invitation
                                                        Organization Invitation Post Schema​
                                                          {} 5 keys
                                                          • "object"
                                                            {} 5 keys
                                                              {} 3 keys
        {} 2 keys
        {} 3 keys
        {} 3 keys
        {} 1 key
        • false
        [] 2 items
        Organization Invitation Post Example​
        {} 2 keys
        • "invitedUser@example.com"
        • "edit"
