Instance Organization Member Actions
https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
Below are the various requests that can be performed against the Instance Organization Member resource, as well as the expected parameters and the potential responses.
Delete​
Deletes an organization member
Method And Url​
DELETE https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgMember.*, or instanceOrgMember.delete.
Request Path Components​
INSTANCE_IDID associated with the instance575ec8687ae143cd83dc4a95
ORG_IDID associated with the organization575ec8687ae143cd83dc4a97
USER_IDID associated with the organization member575ec8687ae143cd83dc4a94
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf member was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if organization or member was not found
Get​
Returns an organization member
Method And Url​
GET https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.Instance.bounded, all.Instance.read, all.User, all.User.bounded, all.User.read, instanceOrgMember.*, or instanceOrgMember.get.
Request Headers​
Curl Example​
CodeTypeDescription
200Instance Org MemberA single organization member
Error Responses​
CodeTypeDescription
404ErrorError if instance, organization, or member was not found
Patch​
Modifies the role of an organization member
Method And Url​
PATCH https://api.losant.com/instances/INSTANCE_ID/orgs/ORG_ID/members/USER_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Instance, all.User, instanceOrgMember.*, or instanceOrgMember.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Instance Org Member Patch schema. For example, the following would be a valid body for this request:
"role": "view"
Curl Example​
-d '{"role":"view"}' \
CodeTypeDescription
200Instance Org MemberThe modified organization member
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Instance Org Member​
        Schema for an Instance Organization member
        Instance Org Member Schema​
          {} 4 keys
          • "object"
            {} 12 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
                    {} 3 keys
                      {} 3 keys
                        {} 2 keys
                          {} 2 keys
                            {} 3 keys
                              {} 3 keys
                                {} 3 keys
                                  {} 1 key
                                    {} 1 key
                                  • false
                                Instance Org Member Example​
                                  {} 2 keys
                                  • "575ef90f7ae143cd83dc4aad"
                                  • "view"
                                Instance Org Member Patch​
                                Schema for an Instance Organization member modification request
                                Instance Org Member Patch Schema​
                                  {} 4 keys
                                  • "object"
                                    {} 3 keys
                                      {} 2 keys
                                        {} 3 keys
                                          {} 3 keys
                                        • false
                                      Instance Org Member Patch Example​
                                        {} 1 key
                                        • "view"
                                      Success​
                                      Success Schema​
                                        {} 3 keys
                                        • "object"
                                          {} 1 key
                                            {} 2 keys
                                        Success Example​
                                          {} 1 key
                                          • true
