Resource Job Actions
https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
Below are the various requests that can be performed against the Resource Job resource, as well as the expected parameters and the potential responses.
Cancel Execution
Marks a specific resource job execution for cancellation
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/cancelExecution
all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.cancelExecution.
| RESOURCE_JOB_ID | ID associated with the resource job | 575ec8687ae143cd83dc4a97 |
| executionId | Y | The ID of the execution to cancel | executionId=632e18632f59592e773a4153 |
https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/cancelExecution?executionId=632e18632f59592e773a4153
| 200 | Success | If the execution was successfully marked for cancellation |
| 404 | Error | Error if execution was not found |
Delete
Deletes a resource job
DELETE https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.delete.
| includeWorkflows | N | If the workflows that trigger from this resource job should also be deleted. | includeWorkflows=true |
| 200 | Success | If resource job was successfully deleted |
| 404 | Error | Error if resource job was not found |
Execute
Queues the execution of a resource job
POST https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/execute
all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.execute.
The body of the request should be serialized JSON that validates against the Resource Job Execution Options schema. For example, the following would be a valid body for this request:
"templateContext": "{ \"myData\": 123 }"
-d '{"templateContext":"{ \"myData\": 123 }"}' \
| 200 | Success With Execution ID | If the job was successfully queued |
Returns a resource job
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJob.*, or resourceJob.get.
| 200 | Resource Job | A single resource job |
Logs
Retrieves information on resource job executions
GET https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID/logs
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, resourceJob.*, or resourceJob.logs.
| limit | N | Max log entries to return (ordered by time descending) | 1 | limit=10 |
| since | N | Look for log entries since this time (ms since epoch) | since=1465790400000 |
| 200 | Resource Job Execution Logs | Resource job execution information |
Patch
Update a resource job
PATCH https://api.losant.com/applications/APPLICATION_ID/resource-jobs/RESOURCE_JOB_ID
all.Application, all.Organization, all.User, resourceJob.*, or resourceJob.patch.
The body of the request should be serialized JSON that validates against the Resource Job Patch schema. For example, the following would be a valid body for this request:
"name": "Example Resource Job",
"queryJson": "{ \"name\": \"my device\"}"
-d '{"name":"Example Resource Job","queryJson":"{ \"name\": \"my device\"}"}' \
| 201 | Resource Job | Successfully updated resource job |
Resource Job
Schema for a single resource job
Resource Job Schema
- ▶{} 19 keys
Resource Job Example
- ▶{} 11 keys
- "Example Resource Job"
- 60
- 60000
- "6328c6c026517badf9142116"
- 1
- "2022-09-19T19:45:04.453Z"
- "6328c6c026517badf914211a"
- "device"
- "{ "name": "my device"}"
Schema for a set of Resource Job execution logs
Resource Job Execution Logs Schema
- "array"
- ▶{} 6 keys
Resource Job Execution Logs Example
- ▶{} 14 keys
Schema for a resource job execution configuration
Resource Job Execution Options Schema
Resource Job Execution Options Example
- "{ "myData": 123 }"
Resource Job Patch
Schema for a resource job update
Resource Job Patch Schema
- ▶{} 12 keys
Resource Job Patch Example
Success
Success Schema
Success Example
Schema for reporting a successful operation with a corresponding execution ID
Success With Execution ID Schema
Success With Execution ID Example
- "575ed78e7ae143cd83dc4aab"
