Solution User Actions
https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users/SOLUTION_USER_ID
Below are the various requests that can be performed against the Solution User resource, as well as the expected parameters and the potential responses.
Delete
Deletes a solution user
DELETE https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users/SOLUTION_USER_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Organization, all.User, solutionUser.*, or solutionUser.delete.
ORG_ID ID associated with the organization 575ed6e87ae143cd83dc4aa8
SOLUTION_ID ID associated with the solution 57955788124b37010084c053
SOLUTIONUSERID ID associated with the solution user 566116085df4b701000258e3
Name Required Description Default
Code Type Description
200 Success If solution user was successfully deleted
404 Error Error if solution user was not found
Retrieves information on a solution user
GET https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users/SOLUTION_USER_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Organization, all.Organization.read, all.User, all.User.read, solutionUser.*, or solutionUser.get.
200 Solution User Solution user information
Patch
Updates information about a solution user
PATCH https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users/SOLUTION_USER_ID
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Organization, all.User, solutionUser.*, or solutionUser.patch.
The body of the request should be serialized JSON that validates against the Solution User Patch schema. For example, the following would be a valid body for this request:
  "password": "aNewUserPassword",
  "forcePasswordResetOnNextLogin": true
    -d '{"password":"aNewUserPassword","forcePasswordResetOnNextLogin":true}' \
200 Solution User Updated solution user information
