Solution Users Actions
https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users
Below are the various requests that can be performed against the Solution Users resource, as well as the expected parameters and the potential responses.
Returns the users for the solution
GET https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Organization, all.Organization.read, all.User, all.User.read, solutionUsers.*, or solutionUsers.get.
ORG_ID ID associated with the organization 575ed6e87ae143cd83dc4aa8
SOLUTION_ID ID associated with the solution 57955788124b37010084c053
Name Required Description Default Example
sortField N Field to sort the results by. Accepted values are: email, firstName, lastName, id, creationDate, lastLogin, lastUpdated email sortField=email
sortDirection N Direction to sort the results by. Accepted values are: asc, desc asc sortDirection=asc
page N Which page of results to return 0 page=0
perPage N How many items to return per page 1000 perPage=10
filterField N Field to filter the results by. Blank or not provided means no filtering. Accepted values are: email, firstName, lastName filterField=email
filter N Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. filter=email*address
Code Type Description
200 Solution Users Collection of solution users
Create a new solution user
POST https://api.losant.com/orgs/ORG_ID/solutions/SOLUTION_ID/users
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Organization, all.User, solutionUsers.*, or solutionUsers.post.
The body of the request should be serialized JSON that validates against the Solution User Post schema. For example, the following would be a valid body for this request:
  "email": "example@solutionuser.com",
  "firstName": "Example",
  "lastName": "Name",
  "password": "aUserPassword",
  "accessRestrictions": {
    "dashboardIds": [
      "575ece2b7ae143cd83dc4a9b",
      "575ece2b7ae143cd83dc4a9c"
    -d '{"email":"example@solutionuser.com","firstName":"Example","lastName":"Name","password":"aUserPassword","accessRestrictions":{"dashboardIds":["575ece2b7ae143cd83dc4a9b","575ece2b7ae143cd83dc4a9c"]}}' \
201 Solution User Successfully created solution user
