User API Token Actions
https://api.losant.com/me/tokens/API_TOKEN_ID
Below are the various requests that can be performed against the User API Token resource, as well as the expected parameters and the potential responses.
Delete
Deletes an API Token
DELETE https://api.losant.com/me/tokens/API_TOKEN_ID
all.User, userApiToken.*, or userApiToken.delete.
| API_TOKEN_ID | ID associated with the API token | 575ec7417ae143cd83dc4a95 |
| 200 | Success | If API token was successfully deleted |
| 404 | Error | Error if API token was not found |
Retrieves information on an API token
GET https://api.losant.com/me/tokens/API_TOKEN_ID
all.User, all.User.read, userApiToken.*, or userApiToken.get.
| 200 | API Token | API token information |
Patch
Updates information about an API token
PATCH https://api.losant.com/me/tokens/API_TOKEN_ID
all.User, userApiToken.*, or userApiToken.patch.
The body of the request should be serialized JSON that validates against the API Token Patch schema. For example, the following would be a valid body for this request:
"name": "My Updated API Token",
"status": "inactive"
-d '{"name":"My Updated API Token","status":"inactive"}' \
| 200 | API Token | Updated API token information |
API Token
Schema for a single API Token
API Token Schema
- ▶{} 15 keys
API Token Example
- ▶{} 13 keys
- "575ec7417ae143cd83dc4a95"
- "575ed70c7ae143cd83dc4aa9"
- "user"
- "application"
- "My API Token"
- "2017-06-13T04:00:00.000Z"
- "active"
- "the_actual_token_string"
API Token Patch
Schema for the body of an API Token modification request
API Token Patch Schema
API Token Patch Example
- "My Updated API Token"
- "inactive"
Success
Success Schema
Success Example
