User API Tokens Actions
https://api.losant.com/me/tokens
Below are the various requests that can be performed against the User API Tokens resource, as well as the expected parameters and the potential responses.
Get​
Returns the API tokens for a user
Method And Url​
GET https://api.losant.com/me/tokens
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, all.User.bounded, all.User.read, only.User, only.User.bounded, only.User.read, userApiTokens.*, or userApiTokens.get.
Request Query Parameters​
sortFieldNField to sort the results by. Accepted values are: name, status, id, creationDate, lastUpdated, expirationDatenamesortField=name
filterFieldNField to filter the results by. Blank or not provided means no filtering. Accepted values are: name, statusfilterField=key
filterNFilter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering.filter=my*token
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200API TokensCollection of API tokens
Error Responses​
CodeTypeDescription
Post​
Create a new API token for a user
Method And Url​
POST https://api.losant.com/me/tokens
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.User, only.User, userApiTokens.*, or userApiTokens.post.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the API Token Post schema. For example, the following would be a valid body for this request:
"name": "My New API Token",
"expirationDate": "2017-06-13T04:00:00.000Z",
"scope": [
"all.Application"
"status": "active"
Curl Example​
-d '{"name":"My New API Token","expirationDate":"2017-06-13T04:00:00.000Z","scope":["all.Application"],"status":"active"}' \
CodeTypeDescription
201API TokenThe successfully created API token
Error Responses​
CodeTypeDescription
Schemas​
API Token​
Schema for a single API Token
API Token Schema​
    {} 3 keys
    • "object"
      {} 19 keys
        {} 2 keys
          {} 2 keys
            {} 2 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
                    {} 2 keys
                      {} 2 keys
                        {} 2 keys
                          {} 3 keys
                            {} 2 keys
                              {} 2 keys
                                {} 2 keys
                                  {} 2 keys
                                    {} 2 keys
                                      {} 3 keys
                                        {} 2 keys
                                          {} 2 keys
                                            {} 2 keys
                                        API Token Example​
                                          {} 13 keys
                                          • "575ec7417ae143cd83dc4a95"
                                          • "575ed70c7ae143cd83dc4aa9"
                                          • "user"
                                          • "575ec8687ae143cd83dc4a97"
                                          • "application"
                                          • "My API Token"
                                          • "2016-06-13T04:00:00.000Z"
                                          • "2017-06-13T04:00:00.000Z"
                                            [] 1 item
                                            • "active"
                                            • "the_actual_token_string"
                                          API Token Post​
                                          Schema for the body of an API Token creation request
                                          API Token Post Schema​
                                            {} 5 keys
                                            • "object"
                                              {} 7 keys
                                                {} 3 keys
                                                  {} 2 keys
                                                    {} 2 keys
                                                      {} 2 keys
                                                        {} 3 keys
                                                          {} 3 keys
                                                            {} 2 keys
                                                          • false
                                                            [] 1 item
                                                          API Token Post Example​
                                                            {} 4 keys
                                                            • "My New API Token"
                                                              [] 1 item
                                                              • "active"
                                                            API Tokens​
                                                            Schema for a collection of API Tokens
                                                            API Tokens Schema​
                                                              {} 3 keys
                                                              • "object"
        {} 13 keys
        {} 2 keys
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 1 key
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 2 keys
        API Tokens Example​
        {} 9 keys
        [] 1 item
        • 1
        • 4
        • 1
        • 0
        • "name"
        • "asc"
        • "application"
        Error​
        Error Schema​
        {} 3 keys
        • "object"
        {} 3 keys
        {} 1 key
        {} 1 key
        {} 2 keys
        Error Example​
        {} 2 keys
        • "NotFound"
        • "Application was not found"
