User Oauth Client Actions
https://api.losant.com/me/oauth-clients/CLIENT_ID
Below are the various requests that can be performed against the User Oauth Client resource, as well as the expected parameters and the potential responses.
Delete
Deletes a private OAuth client
DELETE https://api.losant.com/me/oauth-clients/CLIENT_ID
all.User, only.User, userOauthClient.*, or userOauthClient.delete.
| CLIENT_ID | ID associated with the OAuth client | 575ec7417ae143cd83dc4a95 |
| 200 | Success | If OAuth client was successfully deleted |
| 404 | Error | Error if OAuth client was not found |
Retrieves information on a private OAuth client
GET https://api.losant.com/me/oauth-clients/CLIENT_ID
all.User, all.User.bounded, all.User.read, only.User, only.User.bounded, only.User.read, userOauthClient.*, or userOauthClient.get.
| 200 | User OAuth Client | OAuth client information |
Patch
Updates information about a private OAuth client
PATCH https://api.losant.com/me/oauth-clients/CLIENT_ID
all.User, only.User, userOauthClient.*, or userOauthClient.patch.
The body of the request should be serialized JSON that validates against the User OAuth Client Patch schema. For example, the following would be a valid body for this request:
"client_name": "Updated Private Client Name",
"description": "Updated description",
"redirect_uris": [
"https://example.com/new-callback"
-d '{"client_name":"Updated Private Client Name","description":"Updated description","redirect_uris":["https://example.com/new-callback"]}' \
| 200 | User OAuth Client | Updated OAuth client information |
Success
Success Schema
Success Example
User OAuth Client
Schema for a single private OAuth client
User OAuth Client Schema
- ▶{} 17 keys
User OAuth Client Example
- ▶{} 17 keys
- "575ec7417ae143cd83dc4a95"
- "8f14e45fceea167a5a36dedd4bea2543"
- "My Private Client"
- "Private OAuth client for automation"
- "https://example.com"
- "https://example.com/logo.png"
- ▶[] 2 items
- "client_secret_basic"
- ▶[] 2 items
- "https://example.com/tos"
- "https://example.com/privacy"
Schema for the body of a private OAuth client modification request
User OAuth Client Patch Schema
- ▶{} 10 keys
User OAuth Client Patch Example
- "Updated Private Client Name"
- "Updated description"
