User Oauth Clients Actions
https://api.losant.com/me/oauth-clients
Below are the various requests that can be performed against the User Oauth Clients resource, as well as the expected parameters and the potential responses.
Returns the private OAuth clients for a user
GET https://api.losant.com/me/oauth-clients
all.User, all.User.bounded, all.User.read, only.User, only.User.bounded, only.User.read, userOauthClients.*, or userOauthClients.get.
| sortField | N | Field to sort the results by. Accepted values are: client_name, id, creationDate, lastUpdated | client_name | sortField=client_name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: client_name | filterField=client_name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*app |
| 200 | User OAuth Clients | Collection of private OAuth clients |
Create a new private OAuth client for a user
POST https://api.losant.com/me/oauth-clients
all.User, only.User, userOauthClients.*, or userOauthClients.post.
The body of the request should be serialized JSON that validates against the User OAuth Client Post schema. For example, the following would be a valid body for this request:
"client_name": "My Private Client",
"description": "Private OAuth client for automation",
"client_uri": "https://example.com",
"logo_uri": "https://example.com/logo.png",
"redirect_uris": [
"https://example.com/callback"
"token_endpoint_auth_method": "client_secret_basic",
"scope": [
"only.User.read",
"all.Application.read"
"contacts": [
"admin@example.com"
"tos_uri": "https://example.com/tos",
"policy_uri": "https://example.com/privacy"
-d '{"client_name":"My Private Client","description":"Private OAuth client for automation","client_uri":"https://example.com","logo_uri":"https://example.com/logo.png","redirect_uris":["https://example.com/callback"],"token_endpoint_auth_method":"client_secret_basic","scope":["only.User.read","all.Application.read"],"contacts":["admin@example.com"],"tos_uri":"https://example.com/tos","policy_uri":"https://example.com/privacy"}' \
| 201 | User OAuth Client | The successfully created OAuth client. client_secret is only ever returned on this response. |
User OAuth Client
Schema for a single private OAuth client
User OAuth Client Schema
- ▶{} 17 keys
User OAuth Client Example
- ▶{} 17 keys
- "575ec7417ae143cd83dc4a95"
- "8f14e45fceea167a5a36dedd4bea2543"
- "My Private Client"
- "Private OAuth client for automation"
- "https://example.com"
- "https://example.com/logo.png"
- ▶[] 2 items
- "client_secret_basic"
- ▶[] 2 items
- "https://example.com/tos"
- "https://example.com/privacy"
Schema for the body of a private OAuth client creation request
User OAuth Client Post Schema
- ▶{} 10 keys
- ▶[] 2 items
User OAuth Client Post Example
- ▶{} 10 keys
- ▶[] 2 items
User OAuth Clients
Schema for a collection of private OAuth clients
User OAuth Clients Schema
- ▶{} 9 keys
User OAuth Clients Example
- ▶{} 7 keys
- 1
- 1
- 1000
- 0
- "client_name"
- "asc"
