Group: Create Node
The Group: Create Node allows a workflow to create a new Experience Group inside the current application.
Group: Create Node
The Group: Create Node has two main configuration sections:
Group Configuration​
The "Individual Fields" option allows for a simple configuration.
The "JSON Template" and "Payload Path" options are more advanced options because they give you full control over the group being created.
Group: Create Node Configuration
Individual Fields​
Using this option, the block configuration is separated into various string templates fields:
  • Name—Name of the group.
  • Description—Description of the group.
  • Group Parent—Parent group of the group to be created.
  • Devices—Advanced query that defines the devices to be associated with the created group.
  • Group Tags—Tags to apply to the new group.
  • Members—Initial users to assign to the group as members.
Group: Create Node More Configuration
JSON Template​
The input must be a JSON template string that can be parsed into a JSON object that validates against the Experience Group Post schema:
"description": "{{working.group.description}}",
"name": "{{working.group.name}}"
Payload Path​
The input must be a payload path that points to an object on the current workflow payload that validates against the Experience Group Post schema.
Result​
Optionally, you may provide a payload path at which to place the result of the operation.
Group: Create Node Result
If node execution is successful, this will be the experience group object.
If node execution fails, this will be an object of errors.
Node Example​
Upon successful execution, this is a possible result for a successful group creation:
"groupResult": {
"experienceUserIds": [],
"experienceEndpointIds": [],
"deviceTags": [],
"deviceIds": [],
"id": "5ea72535db6cd100075e95e7",
"experienceGroupId": "5ea72535db6cd100075e95e7",
"lastUpdated": "2020-04-27T18:32:21.631Z",
"creationDate": "2020-04-27T18:32:21.626Z",
"applicationId": "5ea04e5ba2efcc00077a81c8",
"groupTags": {
"warehouse": "3"
"deviceQueryJson": "{\n \"$nor\": [\n{\n \"tags\": {\n\"$eq\": {\n \"$tagKey\": \"warehouse\",\n \"$tagValue\": \"3\"\n}\n }\n}\n ]\n}",
"parentId": "5ea7229c93f1de000702590f",
"description": "Assets belonging to warehouse 3",
"name": "Warehouse 3"
If the Group: Create Node encounters an error, it will be placed on the payload at the configured result path like so:
"groupResult": {
"message": "name is required",
"type": "Validation"
