WebSocket Message Node
The WebSocket Message Node allows you to publish a message to a specific WebSocket integration.
WebSocket Message
Configuration​
The WebSocket Message Node takes three properties:
  • WebSocket Integration: The WebSocket integration to which the message should be published. The integration must be connected for the node to successfully publish. The ID is templatable.
  • Message Encoding: An encoding method for the message (defaults to UTF-8).
  • Message Template: A string template for the message to publish to the integration. If you would like to publish an object or array, the value should be properly encoded.
Notes​
There are a couple considerations to keep in mind when using the WebSocket Message Node ...
Integration Connection Status​
The chosen WebSocket integration must be connected for the node to publish a message; invocations of this node while the integration is disconnected will not queue to send later.
Differences from Webhook Reply​
The WebSocket Message Node should not be confused with the Webhook Reply Node. The WebSocket Message Node only publishes messages to a connected WebSocket integration, whereas the Webhook Reply Node can be configured to publish a message to clients connected to a WebSocket-type Webhook.
Encoding Structured Data​
When using a string template to reference structured data in the message (such as objects or arrays), you must encode the data using a {{jsonEncode}} helper, which will stringify the object. Failure to do so will result in your message being published as "[object Object]".
