Application Certificate Authorities Actions
https://api.losant.com/applications/APPLICATION_ID/certificate-authorities
Below are the various requests that can be performed against the Application Certificate Authorities resource, as well as the expected parameters and the potential responses.
Returns the application certificate authorities for an application
GET https://api.losant.com/applications/APPLICATION_ID/certificate-authorities
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationCertificateAuthorities.*, or applicationCertificateAuthorities.get.
| sortField | N | Field to sort the results by. Accepted values are: name, status, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name, status | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=the*name |
| 200 | Application Certificate Authorities | Collection of application certificate authorities |
Create a new application certificate authority for an application
POST https://api.losant.com/applications/APPLICATION_ID/certificate-authorities
all.Application, all.Organization, all.User, applicationCertificateAuthorities.*, or applicationCertificateAuthorities.post.
The body of the request should be serialized JSON that validates against the Application Certificate Authority Post schema. For example, the following would be a valid body for this request:
  "name": "my certificate authority",
  "description": "An example new authority description",
  "caBundle": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----"
    -d '{"name":"my certificate authority","description":"An example new authority description","caBundle":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----"}' \
| 201 | Application Certificate Authority | Successfully created application certificate authority |
Schema for a collection of Application Certificate Authorities
Application Certificate Authorities Schema
 - ▶{} 10 keys
Application Certificate Authorities Example
- ▶{} 8 keys
 - 1
 - 4
 - 1
 - 0
 - "key"
 - "asc"
Schema for a single Application Certificate Authority
Application Certificate Authority Schema
 - ▶{} 10 keys
Application Certificate Authority Example
- ▶{} 10 keys
- "5cd02a7bdf66feb0994c7197"
 - "active"
 - "my certificate authority"
 - "An example certificate authority description"
 - "-----BEGIN CERTIFICATE-----
MY_SSL_CERTIFICATE
Schema for the body of an Application Certificate Authority creation request
Application Certificate Authority Post Schema
 - ▶[] 2 items
Application Certificate Authority Post Example
 - "An example new authority description"
MY_SSL_CERTIFICATE
