Application Job Log Actions
https://api.losant.com/applications/APPLICATION_ID/jobLogs/JOB_ID
Below are the various requests that can be performed against the Application Job Log resource, as well as the expected parameters and the potential responses.
Returns the job log for the given ID
GET https://api.losant.com/applications/APPLICATION_ID/jobLogs/JOB_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationJobLog.*, or applicationJobLog.get.
| JOB_ID | ID associated with the job execution | 575ec8687ae143cd83dc4a98 |
| 200 | Application Job Log | An application job log |
| 404 | Error | Error if application job log was not found |
Application Job Log
Schema for a single Application Job Log
Application Job Log Schema
- ▶{} 19 keys
- ▶{} 11 keys
- ▶{} 20 keys
Application Job Log Example
- ▶{} 9 keys
- "575ec76c7ae143cd83dc4a96"
- "application"
- "2025-06-10T04:00:00.000Z"
- "2025-06-10T04:00:01.000Z"
- "inProgress"
- "ArchiveData"
