Application Job Logs Actions
https://api.losant.com/applications/APPLICATION_ID/jobLogs
Below are the various requests that can be performed against the Application Job Logs resource, as well as the expected parameters and the potential responses.
Returns the job logs for an application
GET https://api.losant.com/applications/APPLICATION_ID/jobLogs
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationJobLogs.*, or applicationJobLogs.get.
| sortField | N | Field to sort the results by. Accepted values are: name, status, resourceType, runQueuedAt, runStartedAt, runCompletedAt | runQueuedAt | sortField=status |
| query | N | Filter application job logs by a query. See Advanced Application Job Log Query for more details. | query={"name":"ApplicationExport","status":{"$in":["errored","failed","completed"]}} |
| 200 | Application Job Logs | Collection of application job logs |
Schema for advanced application job logs queries
Advanced Application Job Log Query Schema
- ▶{} 11 keys
Advanced Application Job Log Query Example
- "ApplicationExport"
Schema for a collection of Application Job Logs
Application Job Logs Schema
- ▶{} 9 keys
Application Job Logs Example
- ▶{} 7 keys
- 1
- 8
- 1
- 0
- "name"
- "asc"
