Application Keys Actions
https://api.losant.com/applications/APPLICATION_ID/keys
Below are the various requests that can be performed against the Application Keys resource, as well as the expected parameters and the potential responses.
Returns the applicationKeys for an application
GET https://api.losant.com/applications/APPLICATION_ID/keys
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, applicationKeys.*, or applicationKeys.get.
| sortField | N | Field to sort the results by. Accepted values are: key, status, id, creationDate, lastUpdated | creationDate | sortField=creationDate |
| sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=asc |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: key, status | filterField=key | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=the*key | |
| query | N | Application key filter JSON object which overrides the filterField and filter parameters. See Advanced Application Key Query for more details. | query={"$nor":[{"id":"575ec8687ae143cd83dc4a97"},{"description":"my access key"},{"lastUpdated":{"$lt":1612189931000}}]} |
| 200 | Application Keys | Collection of applicationKeys |
Create a new applicationKey for an application
POST https://api.losant.com/applications/APPLICATION_ID/keys
all.Application, all.Organization, all.User, applicationKeys.*, or applicationKeys.post.
The body of the request should be serialized JSON that validates against the Application Key Post schema. For example, the following would be a valid body for this request:
"description": "An example new key description",
"filterType": "all",
"pubTopics": [],
"subTopics": []
-d '{"description":"An example new key description","filterType":"all","pubTopics":[],"subTopics":[]}' \
| 201 | Application Key Post Response | Successfully created applicationKey |
Schema for advanced application key queries
Advanced Application Key Query Schema
- ▶{} 14 keys
Advanced Application Key Query Example
- ▶[] 3 items
Schema for the body of an Application Key creation request
Application Key Post Schema
- ▶{} 6 keys
Application Key Post Example
- "An example new key description"
- "all"
- [] 0 items
- [] 0 items
Schema for a response of Application Key creation
Application Key Post Response Schema
- ▶{} 14 keys
Application Key Post Response Example
- ▶{} 12 keys
- "575ec76c7ae143cd83dc4a96"
- "this_would_be_the_key"
- "active"
- "shhhSecret"
- "An example key description"
- "all"
- [] 0 items
- [] 0 items
Application Keys
Schema for a collection of Application Keys
Application Keys Schema
- ▶{} 10 keys
Application Keys Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "key"
- "asc"
