Audit Logs Actions
https://api.losant.com/orgs/ORG_ID/audit-logs
Below are the various requests that can be performed against the Audit Logs resource, as well as the expected parameters and the potential responses.
Returns the audit logs for the organization
GET https://api.losant.com/orgs/ORG_ID/audit-logs
all.Organization, all.Organization.read, all.User, all.User.read, auditLogs.*, or auditLogs.get.
| ORG_ID | ID associated with the organization | 575ed6e87ae143cd83dc4aa8 |
| sortField | N | Field to sort the results by. Accepted values are: creationDate, responseStatus, actorName | creationDate | sortField=creationDate |
| sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=asc |
| start | N | Start of time range for audit log query | start=1465790400000 | |
| end | N | End of time range for audit log query | end=1465790400000 | |
| auditLogFilter | N | Filters for the audit log query. See Audit Log Filter for more details. | auditLogFilter[primaryTarget][0][type]=Dashboard&auditLogFilter[primaryTarget][1][type]=Application&auditLogFilter[primaryTarget][1][id]=575ec8687ae143cd83dc4a97&auditLogFilter[actor][0][type]=User&auditLogFilter[actor][0][id]=575ed70c7ae143cd83dc4aa9 |
| 200 | Audit Logs | Collection of audit logs |
| 404 | Error | Error if organization was not found |
Audit Log Filter
Schema for the filter of an audit log query
Audit Log Filter Schema
Audit Log Filter Example
- ▶[] 2 items
Audit Logs
Schema for a collection of Audit Logs
Audit Logs Schema
 - ▶{} 8 keys
Audit Logs Example
- ▶{} 8 keys
 - 1
 - 4
 - 1
 - 0
 - "creationDate"
 - "desc"
 - "575ed6e87ae143cd83dc4aa8"
