Device Attribute Actions
https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes/NAME
Below are the various requests that can be performed against the Device Attribute resource, as well as the expected parameters and the potential responses.
Delete
Removes an attribute from a device
DELETE https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes/NAME
all.Application, all.Organization, all.User, deviceAttribute.*, or deviceAttribute.delete.
| DEVICE_ID | ID associated with the device | 575ecf887ae143cd83dc4aa2 |
| NAME | Name of the attribute | voltage |
| 200 | Success | If device attribute was successfully deleted |
| 404 | Error | Error if device attribute was not found |
Retrieves information on a device attribute
GET https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes/NAME
all.Application, all.Application.read, all.Device, all.Device.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceAttribute.*, or deviceAttribute.get.
| 200 | Device Attribute | Device attribute information |
Patch
Updates an attribute on a device
PATCH https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes/NAME
all.Application, all.Organization, all.User, deviceAttribute.*, or deviceAttribute.patch.
The body of the request should be serialized JSON that validates against the Device Attribute Patch schema. For example, the following would be a valid body for this request:
  "description": "my new attribute description"
    -d '{"description":"my new attribute description"}' \
| 200 | Device Attribute | Updated device attribute information |
Device Attribute
Schema for a single Device Attribute
Device Attribute Schema
 - ▶{} 8 keys
Device Attribute Example
- "575ecf887ae143cd83dc4aa2"
 - "voltage"
 - "number"
Schema for the body of a Device Attribute modification request
Device Attribute Patch Schema
Device Attribute Patch Example
- "my new attribute description"
Success
Success Schema
Success Example
