Device Attributes Actions
https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
Below are the various requests that can be performed against the Device Attributes resource, as well as the expected parameters and the potential responses.
Returns the attributes for a device
GET https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
all.Application, all.Application.read, all.Device, all.Device.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceAttributes.*, or deviceAttributes.get.
| DEVICE_ID | ID associated with the device | 575ecf887ae143cd83dc4aa2 |
| sortField | N | Field to sort the results by. Accepted values are: name, dataType | name | sortField=status |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name, dataType | filterField=status | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=number |
| 200 | Device Attributes | Collection of device attributes |
| 404 | Error | Error if device was not found |
Adds a new attribute to a device
POST https://api.losant.com/applications/APPLICATION_ID/devices/DEVICE_ID/attributes
all.Application, all.Organization, all.User, deviceAttributes.*, or deviceAttributes.post.
The body of the request should be serialized JSON that validates against the Device Attribute Post schema. For example, the following would be a valid body for this request:
"name": "voltage",
"dataType": "number"
-d '{"name":"voltage","dataType":"number"}' \
| 201 | Device Attribute | Successfully created device attribute |
Device Attribute
Schema for a single Device Attribute
Device Attribute Schema
- ▶{} 8 keys
Device Attribute Example
- "575ecf887ae143cd83dc4aa2"
- "voltage"
- "number"
Schema for the body of a Device Attribute creation request
Device Attribute Post Schema
- ▶{} 6 keys
- ▶[] 2 items
Device Attribute Post Example
- "voltage"
- "number"
Device Attributes
Schema for a collection of Device Attributes
Device Attributes Schema
- ▶{} 9 keys
Device Attributes Example
- ▶{} 7 keys
- 1
- 1
- "name"
- "asc"
