Device Recipe resource, as well as the expected
Bulk Create
Bulk creates devices using this recipe from a CSV
POST https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID/bulkCreate
A valid api access token is required to access this endpoint. The token must
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.bulkCreate.
Path Component
Description
Example
APPLICATION_ID
ID associated with the application
575ec8687ae143cd83dc4a97
DEVICERECIPEID
ID associated with the device recipe
575ecec57ae143cd83dc4a9f
Name
Required
Description
Default
Authorization
Y
The token for authenticating the request, prepended with Bearer
The body of the request should be serialized JSON that validates against
the Device Recipe Bulk Create Post schema. For example, the following would be a
valid body for this request:
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.delete.
Path Component
Description
Example
APPLICATION_ID
DEVICERECIPEID
Name
Required
Description
Default
Authorization
Y
GET https://api.losant.com/applications/APPLICATION_ID/device-recipes/DEVICE_RECIPE_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceRecipe.*, or deviceRecipe.get.
Path Component
Description
Example
APPLICATION_ID
DEVICERECIPEID
Name
Required
Description
Default
Example
tagsAsObject
N
Return tags as an object map instead of an array
tagsAsObject=true
attributesAsObject
N
Return attributes as an object map instead of an array
attributesAsObject=true
Name
Required
Description
Default
Authorization
Y
all.Application, all.Organization, all.User, deviceRecipe.*, or deviceRecipe.patch.
Path Component
Description
Example
APPLICATION_ID
DEVICERECIPEID
Name
Required
Description
Default
Example
tagsAsObject
N
tagsAsObject=false
attributesAsObject
N
attributesAsObject=false
Name
Required
Description
Default
Authorization
Y
the Device Recipe Patch schema. For example, the following would be a
{"name":"My Updated Device Recipe","deviceName":"Future device name","description":"Description of my updated device recipe","deviceDescription":"Future device description","tags":[{"key":"TagKey","value":"TagValue"}],"attributes":[{"name":"voltage","dataType":"number"}],"deviceClass":"standalone"}
