Device Recipes Actions
https://api.losant.com/applications/APPLICATION_ID/device-recipes
Below are the various requests that can be performed against the Device Recipes resource, as well as the expected parameters and the potential responses.
Returns the device recipes for an application
GET https://api.losant.com/applications/APPLICATION_ID/device-recipes
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, deviceRecipes.*, or deviceRecipes.get.
| sortField | N | Field to sort the results by. Accepted values are: name, id, creationDate, lastUpdated | name | sortField=name |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: name | filterField=name | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my * recipe | |
| tagsAsObject | N | Return tags as an object map instead of an array | tagsAsObject=false | |
| attributesAsObject | N | Return attributes as an object map instead of an array | attributesAsObject=true |
| 200 | Device Recipes | Collection of device recipes |
Create a new device recipe for an application
POST https://api.losant.com/applications/APPLICATION_ID/device-recipes
all.Application, all.Organization, all.User, deviceRecipes.*, or deviceRecipes.post.
The body of the request should be serialized JSON that validates against the Device Recipe Post schema. For example, the following would be a valid body for this request:
"name": "My New Device Recipe",
"deviceName": "Future device name",
"description": "Description of my new device recipe",
"deviceDescription": "Future device description",
"tags": [
"key": "TagKey",
"value": "TagValue"
"attributes": [
"name": "voltage",
"dataType": "number"
"deviceClass": "standalone"
-d '{"name":"My New Device Recipe","deviceName":"Future device name","description":"Description of my new device recipe","deviceDescription":"Future device description","tags":[{"key":"TagKey","value":"TagValue"}],"attributes":[{"name":"voltage","dataType":"number"}],"deviceClass":"standalone"}' \
| 201 | Device Recipe | Successfully created device recipe |
Device Recipe
Schema for a single Device Recipe
Device Recipe Schema
- ▶{} 16 keys
Device Recipe Example
- ▶{} 12 keys
- "575ecec57ae143cd83dc4a9f"
- "Actual recipe name"
- "Future device name"
- "My recipe description"
- "Future device description"
- "standalone"
Device Recipe Post
Schema for the body of a Device Recipe creation request
Device Recipe Post Schema
- ▶{} 11 keys
Device Recipe Post Example
- ▶{} 7 keys
- "My New Device Recipe"
- "Description of my new device recipe"
- "standalone"
Device Recipes
Schema for a collection of Device Recipes
Device Recipes Schema
- ▶{} 10 keys
Device Recipes Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
