Edge Deployment Actions
/edge/deployments/EDGE_DEPLOYMENT_ID
Below are the various requests that can be performed against the Edge Deployment resource, as well as the expected parameters and the potential responses.
Retrieves information on an edge deployment
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, edgeDeployment.*, or edgeDeployment.get.
EDGEDEPLOYMENTID | ID associated with the edge deployment | 575ed78e7ae143cd83dc4aab |
https://api.losant.com/applications/APPLICATION_ID/edge/deployments/EDGE_DEPLOYMENT_ID
Code | Type | Description |
200 | Edge Deployment | Edge deployment information |
404 | Error | Error if edge deployment was not found |
