Edge Deployments Actions
/edge/deployments
Below are the various requests that can be performed against the Edge Deployments resource, as well as the expected parameters and the potential responses.
Returns the edge deployments for an application
/edge/deployments
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, edgeDeployments.*, or edgeDeployments.get.
sortField | N | Field to sort the results by. Accepted values are: id, deviceId, flowId, desiredVersion, currentVersion, creationDate, lastUpdated | lastUpdated | sortField=creationDate |
deviceId | N | Filter deployments to the given Device ID | deviceId=575ecf887ae143cd83dc4aa2 | |
version | N | Filter deployments to the given Workflow Version (matches against both current and desired) | version=myFlowVersion | |
filterEmpty | N | Filter out deployments where both the current and desired version are null. | filterEmpty=true | |
flowId | N | Filter deployments to the given Workflow ID | flowId=575ed18f7ae143cd83dc4aa6 |
https://api.losant.com/applications/APPLICATION_ID/edge/deployments
Code | Type | Description |
200 | Edge Deployments | Collection of edge deployments |
Release
Deploy an edge workflow version to one or more edge devices. Version can be blank, if removal is desired.
/edge/deployments/release
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.release.
The body of the request should be serialized JSON that validates against the Edge Deployment Release schema. For example, the following would be a valid body for this request:
"flowId": "575ed18f7ae143cd83dc4aa6",
"version": "v1.2.3",
"deviceIds": [
"575ecf887ae143cd83dc4aa2"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","version":"v1.2.3","deviceIds":["575ecf887ae143cd83dc4aa2"]}' \
https://api.losant.com/applications/APPLICATION_ID/edge/deployments/release
201 | Success | If deployment release has been initiated successfully |
Remove
Remove all edge deployments from a device, remove all edge deployments of a workflow, or remove a specific workflow from a specific device
/edge/deployments/remove
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.remove.
The body of the request should be serialized JSON that validates against the Edge Deployment Remove schema. For example, the following would be a valid body for this request:
"deviceId": null
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","deviceId":null}' \
https://api.losant.com/applications/APPLICATION_ID/edge/deployments/remove
201 | Success | If deployment removal has been initiated successfully |
Replace
Replace deployments of an edge workflow version with a new version. New version can be blank, if removal is desired.
/edge/deployments/replace
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, edgeDeployments.*, or edgeDeployments.replace.
The body of the request should be serialized JSON that validates against the Edge Deployment Replace schema. For example, the following would be a valid body for this request:
"oldVersion": "v1.2.3",
"newVersion": "v1.2.4"
-d '{"flowId":"575ed18f7ae143cd83dc4aa6","oldVersion":"v1.2.3","newVersion":"v1.2.4"}' \
https://api.losant.com/applications/APPLICATION_ID/edge/deployments/replace
201 | Success | If deployment replacement has been initiated successfully |
