Experience Domains Actions
https://api.losant.com/applications/APPLICATION_ID/experience/domains
Below are the various requests that can be performed against the Experience Domains resource, as well as the expected parameters and the potential responses.
Returns the experience domains for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/domains
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.cli, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.cli, all.User.read, experienceDomains.*, or experienceDomains.get.
APPLICATION_ID ID associated with the application 575ec8687ae143cd83dc4a97
Name Required Description Default
Code Type Description
200 Experience Domains Collection of experience domains
404 Error Error if application was not found
Create a new experience domain for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/domains
A valid api access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Organization, all.User, experienceDomains.*, or experienceDomains.post.
The body of the request should be serialized JSON that validates against the Experience Domain Post schema. For example, the following would be a valid body for this request:
  "domainName": "my.domain.example.com",
  "sslCert": "-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----",
  "sslKey": "-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----",
  "version": "develop"
    -d '{"domainName":"my.domain.example.com","sslCert":"-----BEGIN CERTIFICATE-----\nMY_SSL_CERTIFICATE\n-----END CERTIFICATE-----","sslKey":"-----BEGIN PRIVATE KEY-----\nMY_SSL_KEY\n-----END PRIVATE KEY-----","version":"develop"}' \
201 Experience Domain Successfully created experience domain
