Experience Endpoint Actions
https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID
Below are the various requests that can be performed against the Experience Endpoint resource, as well as the expected parameters and the potential responses.
Delete​
Deletes an experience endpoint
Method And Url​
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Organization, all.Organization.bounded, all.User, all.User.bounded, experienceEndpoint.*, or experienceEndpoint.delete.
Request Path Components​
EXPERIENCE_ENDPOINT_IDID associated with the experience endpoint575ed78e7ae143cd83dc4aab
Request Query Parameters​
includeWorkflowsNIf the workflows that utilize this experience endpoint should also be deleted.includeWorkflows=true
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf experience endpoint was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if experience endpoint was not found
Get​
Retrieves information on an experience endpoint
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.read, experienceEndpoint.*, or experienceEndpoint.get.
versionNVersion of this experience endpoint to returndevelopversion=develop
Request Headers​
Curl Example​
CodeTypeDescription
200Experience EndpointExperience endpoint information
Error Responses​
CodeTypeDescription
Linked Resources​
Retrieves information on resources linked to an experience endpoint
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID/linkedResources
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.read, experienceEndpoint.*, or experienceEndpoint.linkedResources.
versionNVersion of this experience endpoint to querydevelopversion=develop
includeCustomNodesNIf the result of the request should also include the details of any custom nodes referenced by returned workflowsfalseincludeCustomNodes=true
Request Headers​
Curl Example​
CodeTypeDescription
200Experience Linked ResourcesLinked resource information
Error Responses​
CodeTypeDescription
Patch​
Updates information about an experience endpoint
Method And Url​
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/endpoints/EXPERIENCE_ENDPOINT_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Organization, all.Organization.bounded, all.User, all.User.bounded, experienceEndpoint.*, or experienceEndpoint.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Experience Endpoint Patch schema. For example, the following would be a valid body for this request:
"access": "group",
"experienceGroupIds": [
"58c1de6f8f812590d8e82983"
Curl Example​
-d '{"access":"group","experienceGroupIds":["58c1de6f8f812590d8e82983"]}' \
CodeTypeDescription
200Experience EndpointUpdated experience endpoint information
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Experience Endpoint​
        Schema for a single Experience Endpoint
        Experience Endpoint Schema​
          {} 3 keys
          • "object"
            {} 21 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
                    {} 2 keys
                      {} 2 keys
                        {} 2 keys
                          {} 2 keys
                            {} 2 keys
                              {} 2 keys
                                {} 3 keys
                                  {} 2 keys
                                    {} 3 keys
                                      {} 1 key
                                        {} 2 keys
                                          {} 2 keys
                                            {} 2 keys
                                              {} 3 keys
                                                {} 1 key
                                                  {} 1 key
                                                    {} 2 keys
                                                      {} 1 key
                                                  Experience Endpoint Example​
                                                    {} 10 keys
                                                    • "58c1de6c8f812590d8e82980"
                                                    • "575ec8687ae143cd83dc4a97"
                                                    • "2016-06-13T04:00:00.000Z"
                                                    • "/my/route/{id}"
                                                    • true
                                                    • "get"
                                                    • "group"
                                                      [] 1 item
                                                    Experience Endpoint Patch​
                                                    Schema for the body of an Experience Endpoint modification request
                                                    Experience Endpoint Patch Schema​
                                                      {} 4 keys
                                                      • "object"
                                                        {} 10 keys
                                                          {} 2 keys
                                                            {} 3 keys
                                                              {} 1 key
        {} 2 keys
        {} 2 keys
        {} 2 keys
        {} 3 keys
        {} 3 keys
        {} 1 key
        {} 1 key
        • false
        Experience Endpoint Patch Example​
        {} 2 keys
        • "group"
        [] 1 item
        Experience Linked Resources​
        The body of an experience linked resources response
        Experience Linked Resources Schema​
        {} 4 keys
        • "object"
        {} 4 keys
        {} 4 keys
        {} 4 keys
        {} 4 keys
        {} 4 keys
        • false
        Experience Linked Resources Example​
        {} 4 keys
        {} 8 keys
        {} 8 keys
        {} 8 keys
        {} 9 keys
        Success​
        Success Schema​
        {} 3 keys
        • "object"
        {} 1 key
        {} 2 keys
        Success Example​
        {} 1 key
        • true
