Experience Group Actions
https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Below are the various requests that can be performed against the Experience Group resource, as well as the expected parameters and the potential responses.
Delete​
Deletes an experience group
Method And Url​
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Organization, all.Organization.bounded, all.User, all.User.bounded, experienceGroup.*, or experienceGroup.delete.
Request Path Components​
EXPERIENCE_GROUP_IDID associated with the experience group575ed78e7ae143cd83dc4aab
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200SuccessIf experience group was successfully deleted
Error Responses​
CodeTypeDescription
404ErrorError if experience group was not found
Get​
Retrieves information on an experience group
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.read, experienceGroup.*, or experienceGroup.get.
Request Query Parameters​
includeDirectDeviceCountNWhether or not to return count of devices associated directly with this groupfalseincludeDirectDeviceCount=true
includeTotalDeviceCountNWhether or not to return count of devices associated with this group or any of its descendantsfalseincludeTotalDeviceCount=true
Request Headers​
Curl Example​
CodeTypeDescription
200Experience GroupExperience group information
Error Responses​
CodeTypeDescription
Patch​
Updates information about an experience group
Method And Url​
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/groups/EXPERIENCE_GROUP_ID
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Organization, all.Organization.bounded, all.User, all.User.bounded, experienceGroup.*, or experienceGroup.patch.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Experience Group Patch schema. For example, the following would be a valid body for this request:
"name": "My New Group Name",
"experienceUserIds": [
"575ed70c7ae143cd83dc4aa9",
"675ed70c7ae143cd83dc4aa9"
"experienceEndpointIds": [
"58b9d743cbfafe1be675744b",
"58b9d743cbfafe1be675744c"
"parentId": "775ed70c7ae143cd83dc4aa9",
"deviceIds": [
"58b9d743cbfafe1be675744d"
"deviceTags": [
"key": "myKey",
"value": "foo"
Curl Example​
-d '{"name":"My New Group Name","experienceUserIds":["575ed70c7ae143cd83dc4aa9","675ed70c7ae143cd83dc4aa9"],"experienceEndpointIds":["58b9d743cbfafe1be675744b","58b9d743cbfafe1be675744c"],"parentId":"775ed70c7ae143cd83dc4aa9","deviceIds":["58b9d743cbfafe1be675744d"],"deviceTags":[{"key":"myKey","value":"foo"}]}' \
CodeTypeDescription
200Experience GroupUpdated experience group information
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Experience Group​
        Schema for a single Experience Group
        Experience Group Schema​
          {} 3 keys
          • "object"
            {} 17 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
                    {} 2 keys
                      {} 2 keys
                        {} 3 keys
                          {} 2 keys
                            {} 3 keys
                              {} 3 keys
                                {} 3 keys
                                  {} 3 keys
                                    {} 3 keys
                                      {} 2 keys
                                        {} 1 key
                                          {} 3 keys
                                            {} 1 key
                                              {} 1 key
                                          Experience Group Example​
                                            {} 8 keys
                                            • "58b9d794cbfafe1be675744f"
                                            • "575ec8687ae143cd83dc4a97"
                                            • "2016-06-13T04:00:00.000Z"
                                            • "My Group"
                                              [] 2 items
                                                [] 2 items
                                              Experience Group Patch​
                                              Schema for the body of an Experience Group modification request
                                              Experience Group Patch Schema​
                                                {} 4 keys
                                                • "object"
                                                  {} 9 keys
                                                    {} 3 keys
                                                      {} 2 keys
                                                        {} 3 keys
                                                          {} 3 keys
                                                            {} 3 keys
                                                              {} 3 keys
        {} 3 keys
        {} 2 keys
        {} 1 key
        • false
        Experience Group Patch Example​
        {} 6 keys
        • "My New Group Name"
        [] 2 items
        [] 2 items
        • "775ed70c7ae143cd83dc4aa9"
        [] 1 item
        [] 1 item
        Success​
        Success Schema​
        {} 3 keys
        • "object"
        {} 1 key
        {} 2 keys
        Success Example​
        {} 1 key
        • true
