Experience Slug Actions
https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
Below are the various requests that can be performed against the Experience Slug resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience slug
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
all.Application, all.Organization, all.User, experienceSlug.*, or experienceSlug.delete.
| EXPERIENCE_SLUG_ID | ID associated with the experience slug | 575ed78e7ae143cd83dc4aab |
| 200 | Success | If experience slug was successfully deleted |
| 404 | Error | Error if experience slug was not found |
Retrieves information on an experience slug
GET https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceSlug.*, or experienceSlug.get.
| 200 | Experience Slug | Experience slug information |
Patch
Updates information about an experience slug
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/slugs/EXPERIENCE_SLUG_ID
all.Application, all.Organization, all.User, experienceSlug.*, or experienceSlug.patch.
The body of the request should be serialized JSON that validates against the Experience Slug Patch schema. For example, the following would be a valid body for this request:
"slug": "my-new-slug",
"version": null
-d '{"slug":"my-new-slug","version":null}' \
| 200 | Experience Slug | Updated experience slug information |
Experience Slug
Schema for a single Experience Slug
Experience Slug Schema
- ▶{} 7 keys
Experience Slug Example
- ▶{} 7 keys
- "5b995e51ea9994b50d745284"
- "my-custom-slug"
- "develop"
Schema for the body of an Experience Slug modification request
Experience Slug Patch Schema
Experience Slug Patch Example
- "my-new-slug"
- null
Success
Success Schema
Success Example
