Experience Slugs Actions
https://api.losant.com/applications/APPLICATION_ID/experience/slugs
Below are the various requests that can be performed against the Experience Slugs resource, as well as the expected parameters and the potential responses.
Get​
Returns the experience slugs for an application
Method And Url​
GET https://api.losant.com/applications/APPLICATION_ID/experience/slugs
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Application.cli, all.Application.read, all.Organization, all.Organization.bounded, all.Organization.read, all.User, all.User.bounded, all.User.cli, all.User.read, experienceSlugs.*, or experienceSlugs.get.
Request Path Components​
Request Headers​
Curl Example​
Successful Responses​
CodeTypeDescription
200Experience SlugsCollection of experience slugs
Error Responses​
CodeTypeDescription
Post​
Create a new experience slug for an application
Method And Url​
POST https://api.losant.com/applications/APPLICATION_ID/experience/slugs
Authentication​
A valid API access token is required to access this endpoint. The token must include at least one of the following scopes: all.Application, all.Application.bounded, all.Organization, all.Organization.bounded, all.User, all.User.bounded, experienceSlugs.*, or experienceSlugs.post.
Request Headers​
Request Body​
The body of the request should be serialized JSON that validates against the Experience Slug Post schema. For example, the following would be a valid body for this request:
"slug": "my-custom-slug",
"version": "develop"
Curl Example​
-d '{"slug":"my-custom-slug","version":"develop"}' \
CodeTypeDescription
201Experience SlugSuccessfully created experience slug
Error Responses​
CodeTypeDescription
Schemas​
Error​
Error Schema​
    {} 3 keys
    • "object"
      {} 3 keys
        {} 1 key
          {} 1 key
            {} 2 keys
        Error Example​
          {} 2 keys
          • "NotFound"
          • "Application was not found"
        Experience Slug​
        Schema for a single Experience Slug
        Experience Slug Schema​
          {} 3 keys
          • "object"
            {} 7 keys
              {} 2 keys
                {} 2 keys
                  {} 2 keys
                    {} 2 keys
                      {} 2 keys
                        {} 4 keys
                          {} 3 keys
                      Experience Slug Example​
                        {} 7 keys
                        • "5b995e51ea9994b50d745284"
                        • "575ec8687ae143cd83dc4a97"
                        • "2016-06-13T04:00:00.000Z"
                        • "my-custom-slug"
                        • "develop"
                      Experience Slug Post​
                      Schema for the body of an Experience Slug creation request
                      Experience Slug Post Schema​
                        {} 5 keys
                        • "object"
                          {} 2 keys
                            {} 1 key
                              {} 4 keys
                            • false
                              [] 1 item
                            Experience Slug Post Example​
                              {} 2 keys
                              • "my-custom-slug"
                              • "develop"
                            Experience Slugs​
                            Schema for a collection of Experience Slugs
                            Experience Slugs Schema​
                              {} 3 keys
                              • "object"
                                {} 8 keys
                                  {} 2 keys
                                    {} 1 key
                                      {} 1 key
                                        {} 1 key
                                          {} 1 key
                                            {} 1 key
                                              {} 2 keys
                                                {} 2 keys
                                            Experience Slugs Example​
                                              {} 4 keys
                                                [] 1 item
                                                • 1
                                                • 1
