Experience User Actions
https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
Below are the various requests that can be performed against the Experience User resource, as well as the expected parameters and the potential responses.
Delete
Deletes an experience user
DELETE https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
all.Application, all.Organization, all.User, experienceUser.*, or experienceUser.delete.
| EXPERIENCE_USER_ID | ID associated with the experience user | 575ed78e7ae143cd83dc4aab |
| 200 | Success | If experience user was successfully deleted |
| 404 | Error | Error if experience user was not found |
Retrieves information on an experience user
GET https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceUser.*, or experienceUser.get.
| 200 | Experience User | Experience user information |
Patch
Updates information about an experience user
PATCH https://api.losant.com/applications/APPLICATION_ID/experience/users/EXPERIENCE_USER_ID
all.Application, all.Organization, all.User, experienceUser.*, or experienceUser.patch.
The body of the request should be serialized JSON that validates against the Experience User Patch schema. For example, the following would be a valid body for this request:
"password": "aNewPassword",
"userTags": {
"customKey": "newCustomValue"
-d '{"password":"aNewPassword","userTags":{"customKey":"newCustomValue"}}' \
| 200 | Experience User | Updated experience user information |
Experience User
Schema for a single Experience User
Experience User Schema
- ▶{} 14 keys
Experience User Example
- ▶{} 12 keys
- "58b9d782cbfafe1be675744d"
- "experienceuser@example.com"
- "Example"
- "Name"
- "https://example.avatar.url/is_here.png"
Schema for the body of an Experience User modification request
Experience User Patch Schema
- ▶{} 7 keys
Experience User Patch Example
- "aNewPassword"
Success
Success Schema
Success Example
