Experience Users Actions
https://api.losant.com/applications/APPLICATION_ID/experience/users
Below are the various requests that can be performed against the Experience Users resource, as well as the expected parameters and the potential responses.
Returns the experience users for an application
GET https://api.losant.com/applications/APPLICATION_ID/experience/users
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, experienceUsers.*, or experienceUsers.get.
| sortField | N | Field to sort the results by. Accepted values are: firstName, lastName, email, id, creationDate, lastLogin, lastUpdated | sortField=email | |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: firstName, lastName, email | filterField=email | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*user | |
| experienceGroupId | N | Filter users to those only in the specified group, special experienceGroupIds of 'any' which will give users who are in at least one group and 'none' will give you users who are not in any groups. | experienceGroupId=575ec8687ae143cd83dc4a97 | |
| includeAncestorGroups | N | If set will include members from ancestors of the specified experienceGroupId | includeAncestorGroups=true | |
| query | N | Experience user filter JSON object which overrides all other filter params. See Advanced Experience User Query for more details. | query={"firstName":"Bob","lastUpdated":"2022-01-30T17:18:11.911Z"} |
| 200 | Experience Users | Collection of experience users |
Create a new experience user for an application
POST https://api.losant.com/applications/APPLICATION_ID/experience/users
all.Application, all.Organization, all.User, experienceUsers.*, or experienceUsers.post.
The body of the request should be serialized JSON that validates against the Experience User Post schema. For example, the following would be a valid body for this request:
"email": "experienceuser@example.com",
"firstName": "Example",
"lastName": "Name",
"password": "aUserPassword",
"userTags": {
"customKey": "customValue"
-d '{"email":"experienceuser@example.com","firstName":"Example","lastName":"Name","password":"aUserPassword","userTags":{"customKey":"customValue"}}' \
| 201 | Experience User | Successfully created experience user |
Schema for advanced experience user queries
Advanced Experience User Query Schema
- ▶{} 13 keys
Advanced Experience User Query Example
- "Bob"
- "2022-01-30T17:18:11.911Z"
Experience User
Schema for a single Experience User
Experience User Schema
- ▶{} 14 keys
Experience User Example
- ▶{} 12 keys
- "58b9d782cbfafe1be675744d"
- "experienceuser@example.com"
- "Example"
- "Name"
- "https://example.avatar.url/is_here.png"
Schema for the body of an Experience User creation request
Experience User Post Schema
- ▶{} 7 keys
- ▶[] 2 items
Experience User Post Example
- "Example"
- "Name"
- "aUserPassword"
Experience Users
Schema for a collection of Experience Users
Experience Users Schema
- ▶{} 11 keys
Experience Users Example
- ▶{} 8 keys
- 1
- 4
- 1
- 0
- "name"
- "asc"
