Workflow Version Actions
https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID
Below are the various requests that can be performed against the Workflow Version resource, as well as the expected parameters and the potential responses.
Delete
Deletes a flow version
DELETE https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID
all.Application, all.Organization, all.User, flowVersion.*, or flowVersion.delete.
| FLOW_ID | ID associated with the flow | 575ed18f7ae143cd83dc4aa6 |
| FLOW_VERSION_ID | Version ID or version name associated with the flow version | 675ed18f7ae143cd83dc4bb7 |
| 200 | Success | If flow version was successfully deleted |
| 404 | Error | Error if flow version was not found |
Errors
Get information about errors that occurred during runs of this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/errors
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.errors.
| duration | N | Duration of time range in milliseconds | 86400000 | duration=86400000 |
| end | N | End of time range in milliseconds since epoch | 0 | end=0 |
| limit | N | Maximum number of errors to return | 25 | limit=25 |
| sortDirection | N | Direction to sort the results by. Accepted values are: asc, desc | desc | sortDirection=desc |
| deviceId | N | For edge workflows, the Device ID to return workflow errors for. When not included, will be errors for all device IDs. | deviceId=575ed18f7ae143cd83dc4bb6 |
| 200 | Workflow Errors | Workflow error information |
Retrieves information on a flow version
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.get.
| includeCustomNodes | N | If the result of the request should also include the details of any custom nodes referenced by the returned workflows | false | includeCustomNodes=true |
| 200 | Workflow Version | Flow version information |
Get Log Entries
Retrieve the recent log entries about runs of this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/logs
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.log.
| limit | N | Max log entries to return (ordered by time descending) | 1 | limit=10 |
| since | N | Look for log entries since this time (ms since epoch) | since=1465790400000 |
| 200 | Workflow Log | Recent log entries |
Patch
Updates information about a flow version
PATCH https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID
all.Application, all.Organization, all.User, flowVersion.*, or flowVersion.patch.
The body of the request should be serialized JSON that validates against the Workflow Version Patch schema. For example, the following would be a valid body for this request:
"notes": "Updated workflow version notes",
"enabled": false
-d '{"notes":"Updated workflow version notes","enabled":false}' \
| 200 | Workflow Version | Updated flow version information |
Stats
Get statistics about workflow runs for this workflow version
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/FLOW_VERSION_ID/stats
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersion.*, or flowVersion.stats.
| resolution | N | Resolution in milliseconds | 3600000 | resolution=3600000 |
| deviceId | N | For edge workflows, the device ID to return workflow stats for. When not included, will be aggregate for all device IDs. | deviceId=575ed18f7ae143cd83dc4bb6 |
| 200 | Workflow Statistics | Statistics for workflow runs |
Workflow Errors
Workflow run error information
Workflow Errors Schema
- ▶{} 8 keys
Workflow Errors Example
- "2016-06-03T00:00:00.000Z"
- "2016-06-04T00:00:00.000Z"
- 25
- "desc"
Workflow Log
Log of aggregated workflow run information
Workflow Log Schema
- "array"
Workflow Log Example
- ▶[] 2 items
- ▶{} 7 keys
- ▶{} 7 keys
Workflow Statistics
Statistics about the runs for a given workflow
Workflow Statistics Schema
- ▶{} 7 keys
Workflow Statistics Example
- 86400000
Workflow Version
Schema for a single Workflow Version
Workflow Version Schema
- ▶[] 2 items
Workflow Version Example
- ▶{} 13 keys
- "675ed18f7ae143cd83dc4bb7"
- "575ed18f7ae143cd83dc4aa6"
- "Description of my workflow version"
- "experience"
- [] 0 items
- [] 0 items
- [] 0 items
Schema for the body of a Workflow Version modification request
Workflow Version Patch Schema
Workflow Version Patch Example
- "Updated workflow version notes"
Success
Success Schema
Success Example
