Workflow Versions Actions
https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions
Below are the various requests that can be performed against the Workflow Versions resource, as well as the expected parameters and the potential responses.
Delete
Delete flow versions
POST https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions/delete
all.Application, all.Organization, all.User, flowVersions.*, or flowVersions.delete.
| FLOW_ID | ID associated with the flow | 575ed18f7ae143cd83dc4aa6 |
The body of the request should be serialized JSON that validates against the Flow Versions Delete Post schema. For example, the following would be a valid body for this request:
"query": {
"version": {
"$ne": "versionToKeep"
"email": "email@example.com"
-d '{"query":{"version":{"$ne":"versionToKeep"}},"email":"email@example.com"}' \
| 200 | Bulk Deletion Response | Object indicating number of flow versions deleted or failed |
| 202 | Job Enqueued API Result | If a job was enqueued for the flow versions to be deleted |
Returns the flow versions for a flow
GET https://api.losant.com/applications/APPLICATION_ID/flows/FLOW_ID/versions
all.Application, all.Application.read, all.Organization, all.Organization.read, all.User, all.User.read, flowVersions.*, or flowVersions.get.
| sortField | N | Field to sort the results by. Accepted values are: version, id, creationDate, lastUpdated | version | sortField=version |
| filterField | N | Field to filter the results by. Blank or not provided means no filtering. Accepted values are: version | filterField=version | |
| filter | N | Filter to apply against the filtered field. Supports globbing. Blank or not provided means no filtering. | filter=my*version | |
| includeCustomNodes | N | If the result of the request should also include the details of any custom nodes referenced by the returned workflows | false | includeCustomNodes=true |
| query | N | Workflow filter JSON object which overrides the filterField and filter parameters. See Advanced Workflow Version Query for more details. | query={"version":"theVersion"} |
| 200 | Workflow Versions | Collection of flow versions |
| 404 | Error | Error if flow was not found |
Create or replace a flow version for a flow
all.Application, all.Organization, all.User, flowVersions.*, or flowVersions.post.
| allowReplacement | N | Allow replacement of an existing flow version with same version name | false | allowReplacement=true |
The body of the request should be serialized JSON that validates against the Workflow Version Post schema. For example, the following would be a valid body for this request:
"version": "v1.2.3",
"notes": "Notes about my new workflow version",
"enabled": false
-d '{"version":"v1.2.3","notes":"Notes about my new workflow version","enabled":false}' \
| 201 | Workflow Version | Successfully created flow version |
Schema for advanced workflow queries
Advanced Workflow Version Query Schema
- ▶{} 13 keys
Advanced Workflow Version Query Example
- "theVersion"
Schema for the response to a bulk deletion
Bulk Deletion Response Schema
Bulk Deletion Response Example
- 3
Workflow Version
Schema for a single Workflow Version
Workflow Version Schema
- ▶[] 2 items
Workflow Version Example
- ▶{} 13 keys
- "675ed18f7ae143cd83dc4bb7"
- "575ed18f7ae143cd83dc4aa6"
- "Description of my workflow version"
- "experience"
- [] 0 items
- [] 0 items
- [] 0 items
Schema for the body of a Workflow Version creation request
Workflow Version Post Schema
- ▶{} 8 keys
Workflow Version Post Example
- "v1.2.3"
- "Notes about my new workflow version"
Workflow Versions
Schema for a collection of Workflow Versions
Workflow Versions Schema
- ▶{} 11 keys
Workflow Versions Example
- ▶{} 9 keys
- 1
- 4
- 1
- 0
- "version"
- "asc"
Schema for the body of a bulk flow versions delete request
Flow Versions Delete Post Schema
Flow Versions Delete Post Example
- "email@example.com"
Job Enqueued API Result Schema
Job Enqueued API Result Example
- "clnHvJbyVkOWAZwYAwLP4"
